Lscott
    106
Everything posted by Lscott
  1. That seems to be the case. I have several UHF radios in my collection. Some are certified Part 95A, the old rules, NX-300's. Those have a stated official frequency range of 450 to 520 with the FCC ID ALH378500. Those are Part 95A. The exact same model with a stated official frequency range of 406.1 to 470, FCC ID ALH378501 are NOT Part 95A certified. The frequency ranges above are what appears on the FCC grants. Note both cover the GMRS frequencies. The difference is the second one also covers the US Ham 70cm band too. I can't say if the lack of Part 95A certification is due to the manufacture not applying for it or if the FCC wouldn't give the certification. https://comms.kenwood.com/common/pdf/download/02_NX-200G&300GBrochure.pdf Also note the radio can do digital voice mode even with the Part 95A certification. Of course that in noway implies using digital voice on GMRS is currently legal.
  2. That's a bit fuzzy. The rules state if the radio is equipped with frequencies not listed in the table, approved for GMRS, then it doesn't meet certification. I guess that depends on how one defines "equipped", is the radio designed that way or just programmed with frequencies in both services? I have my radios setup for both since I'm licensed for both services.
  3. This page has a nice listing of the various FCC designators. https://digitalfrequencysearch.com/Search/Codes.php
  4. You really have that all screwed up. I would HIGHLY suggest you go and read in detail Part 97 for the Armature Radio Service and Part 95E for GMRS. If it doesn't make sense the first time through then read it again, and again ... Most, if not all, of the answers are there. It might take awhile for it to sink in. https://www.law.cornell.edu/cfr/text/47/part-97 https://www.law.cornell.edu/cfr/text/47/part-95/subpart-E If you have specific questions about any of the rules parts members here are glad to help in that area.
  5. These are several photos for a GPSDO, GPS satellite disciplined oscillator, that gives near atomic clock frequency accuracy. The electronics locks onto the 1 PPS, 1 pulse per second, signal and over a long period of time and adjusts the frequency of an oven stabilized quartz oscillator to the desired value. In this case it's 10MHz. Frequency test equipment have provisions for an external frequency source to use in place of the usual internal one. I believed somebody tested one of these and measured the frequency, against a high precision atomic clock, at 9,999,999.9998 Hz once it stabilized. Radio shops and labs use frequency standards, not necessarily this one, with a distribution amplifier to all their scopes, frequency generators, frequency counters and spectrum analyzers. This way any drift or calibration differences between them is eliminated when making frequency and timing measurements.
  6. Seeing how Baofengs are disparaged here I wonder just how well they hold up in the field. I guess any radio is better than none. As cheap as they are a truck load isn't that expensive. As a point of comparison the old WWII man-pack radios only did 0.3 watts on low band VHF. The range was about 3 miles with the long antenna. https://en.wikipedia.org/wiki/SCR-300 https://olive-drab.com/od_electronics_scr300.php
  7. Ah, one of the golf cart drivers! I'll have to keep my eye out for you then.
  8. Lscott
    NX-300
    Here is one of my NX-300's, one of the "intrinsically safe" models, at the office I'm testing by letting it scan. I just got it back from being serviced, tested and setup per spec's. It does analog FM and NXDN digital modes.
  9. Lscott
    TK-5320
    A Kenwood TK-5320 radio I purchased from eBay. Does analog FM and P25 digital.
  10. I was surprised that commercial grade radios were being used. If CCR's are being used I guess it could be worse.
  11. How many are planing on going to the Dayton Hamvention this year? Could setup a frequency and location where people on the forums here could arrange to met up for a quick chat in person.
  12. Wrong. As others have pointed out it’s allowed in the rules. You should really go and read them. If you didn’t understand them the first time through go and read them again. The confusing part is communications between FRS and GMRS radios. Each operates under their respective rules parts. If you’re using a GMRS compliant radio, talking to an FRS radio, then you must follow ALL the GMRS rules including ID’ing yourself. The FRS radio user does not. FRS radios by design, FCC requirements for certification, can’t access the repeater input channel frequencies so the issue there is moot. The FCC created this mess by allowing the sale of combination FRS/GMRS radios in the first place. The box contained information stating the channels above 14 can’t be used unless one had a valid GMRS license. Almost nobody read that, or if they did just ignored it. Finally the FCC changed the rules which became effective in 2018 making the wide spread practice legal so they didn’t have to deal with the enforcement issue. So we have the weird situation where two radio services share the exact same frequencies AND are allowed to cross communicate. Sooner or later newbies start asking about cross communications between Ham 70cm and GMRS. Technically it’s possible with certain radios using no modifications for out of band operations. Forget it. It’s not legal due to some rules mainly on the Ham side. That’s the conclusions I reached after looking at it myself years back. This topic has been covered on these forums before as well.
  13. I look at what I've paid at Ham swaps verses what people charge on eBay, which IMHO is way TOO much. Every once in a while somebody sells a radio at a supper good deal. I'm still kicking myself for missing a new NX-200 for $135. It was up for maybe 15 to 30 minutes and was gone before I could hit the buy it now button. I just recently snagged a Kenwood TK-2180 with battery pack, charger base, antenna and speaker microphone for $40 at a local Ham swap a few weeks ago. And yes it works. On eBay you're looking at $100 to $200 for just the radio! At another swap I found a Kenwood TH-79A with accessories in good condition for $35. You get the idea.
  14. That might be a good illustration of free space “path loss”, due to the capture area of the antenna at 900 being less that at 460. https://en.wikipedia.org/wiki/Free-space_path_loss
  15. I’m planing going to the Dayton Hamvention this year with a couple of buddies. I thought about looking for a good deal on a 7550e. I’m not fond of the funky antenna connector but I’ll consider getting it just to try out. At $500 plus, that’s way too much for something I’ll just be experimenting with. The 6550’s I got for less than a $100 each. The 6580 I got was in like new condition with battery pack, charger and programmed for a number of Ham 33cm repeaters for $85 at a Ham swap.
  16. What kind of range were you getting with the TK-3170 at 4 watts?
  17. I'm mainly a big Kenwood guy but I do own several Motorola XPR-6550's, VHF and low split UHF, models. They were fairly cheap compared to the XPR7550e's I've seen. I have the cables and software to program them. I've even got a XPR-6580 800/900 MHz radio. Then with a little bit of in memory hex editing on the CPS you can get those on the Ham 33cm band easy.
  18. Yeah!!! I don't want this thread to be about any politics. I'm just interested in the radio technology being used. Sort of surprising that regular commercial radios are being used. I would have thought highly encrypted digital radios designed specifically for military use would be the norm.
  19. Lscott
    GMRS cost
    MURS is limited to 2 watts max. You can use a portable with a speaker mic with an external antenna. There are some commercial radios that likely can be programed to use MURS as long as the channel bandwidth and power limitations are observed. Those radios aren't that expensive used if you shop around. See an old thread on the topic. https://forums.mygmrs.com/topic/1239-old-part-90-radios-predating-murs-service-legal-use/
  20. I wonder if anybody in the US has heard the short wave communications? At least any that are identifiable as such.
  21. I was doing some searching for some digital radio info and stumbled across this. Perhaps this is why the Russians are having trouble, using crappy CCR radios? https://defence-blog.com/russian-soldiers-uses-chinese-portable-radios-during-kremlins-invasion-of-ukraine/ I guess the Ukrainian military are using Motorola radios. https://k0lwc.com/what-radios-are-ukrainian-military-using/
  22. I got the cheapest one they make. For battery pack testing and playing with solar panels you don’t need the more expensive models.
