RogerSpendlove
    Wilkes County, NC
RogerSpendlove's Achievements
  1. Thanks, everyone for the excellent advice! Much appreciated! I decided to purchase a mag-mount antenna for myself. It will give me the additional flexibility of being able to put it on another vehicle, in case I'm driving the church van with a bunch of boys and dads, instead of my personal vehicle. Plus, it was a lot less expensive than the mobile unit! Maybe I'll eventually be able to convince the other dads to invest in one as well (first have to convince them to get their own handhelds and license!) Thanks again!
  2. I'm still fairly new to radios and GMRS and trying to get my mind wrapped around the technical concepts. My intended use is for communications between multiple drivers transporting a group of young men to camping outings (we're a Trail Life USA troop). I'm contemplating getting a 20w mobile to install into my car (because, or course, I'm attracted to the possibility of farther range ). But most of the other dads would likely be using 5w handhelds in their vehicles. My question is: I, with my 20w would be able to transmit farther (in most conditions) than the 5w handhelds -- so does that mean that if we got separated a number of miles on the highway, they would be able to hear me from farther away, but that I would probably NOT be able to hear them calling back, due to their lower power? For transportation communications like this, would it be better for all of us to have the same power handhelds? Thanks for any help and insight you'all could give me.
  3. I found replacement belt clips on Amazon saying they're compatible with the Baofeng UV-5R series. Can anyone confirm whether the screw hole placement on the UV-5R is the same as on the GM-15 PRO ? My GM-15 PRO unit measures 1 inch on center. They sure look the same, but I'm just trying to be sure before I commit to spending $. Thanks!
  4. I have a pair of B-Tech GM-15 handhelds, and one of the screws fastening the belt-clip has been lost. Can anyone tell me what size and thread-count is that tiny little screw, and where I could purchase one? It's far smaller than the smallest thing I can find at Lowes Home Improvement! Or better yet, does anyone sell compatible replacement belt clips--with a stronger spring that doesn't allow the radio to come loose at the slightest jostling? Thanks for any help!
  5. I just installed the MyGMRS Ap on my iPhone (running iOS 18.1.1). When I try to log-in using the exact same credentials as I use to log-in to this website, it tells me "The credentials you have provided are incorrect. Please try again." Anyone have any idea why this is happening? Do I have to set-up an entirely different account to use the ap? Thanks for your help!
  6. Writing as a newbie to radios, I definitely sought a book to educate myself on how they work and how I can implement them in what I want to do. I looked at the plethora of "Baofeng" books on Amazon and was put-off by their back-woods prepper mentality. Also, from reading their sample chapters, I found most of their writing style/competency was very low, and chapter lists revealed tons of repetition. I settled on "The New Operator's Guide to GMRS" by Jim Mohan, which I found very helpful. Yet, in this very slim volume, there were redundant sections, and several chapters I found useless (by the time a newbie is buying a book, he's not needing help determining if GMRS is right for me; also didn't need instruction on applying for the license--that's way too convoluted to be covered in a book). Even as a newbie, it was almost too basic and broad. I have watched lots of YouTube videos. Those from BuyTwoWayRadios.com and Jim Mohan were pretty helpful. But most of the others I've stumbled upon (HamRadioforNonTechies, HamRadioCrashCourse) I found to be tedious and unhelpful. Like 90% of all YouTubers, they're just a guy in front of a greenscreened cool /fake background, sitting there and blathering into the camera unscripted. A 20 minute video contains maybe 1.5 minutes of actual information. I wish I could find some truly helpful videos, where the author planned out a script of educational information to convey, delivered it, used video to SHOW (diagrams, illustrations, charts, etc.) and not just TELL. Have you all here in MyGMRS found any videos like that you'd recommend? (BTW, I've come to the conclusion that Ham is not for me -- GMRS is what I need). Thanks!
  7. Thank you all for your responses! They've been most helpful. I'm traveling to / camping in the area of this repeater this weekend, so I'll get to find out if I've programmed my HTs properly. But if not, you'all have armed me with the understanding to probably correct it!
  8. Never mind! I didn't see Socalgmrs's reply above!
  9. Thank you for answering! Do you happen to know what is the difference between the 'N' and the 'I' options? I see both in the programming software, but in the transceiver itself, only the N options appear.
  10. A repeater I'm wanting to connect to is listed as having Input Tone "265 DPL," but this doesn't match any of the options in my Radiodity GM-30 (actually a Baifeng GM-15) software. The options I see are "D265N" and "D264I." Which one should I use? And should I enter this my my transceiver's Rx DCS or its Rx CTCSS?
