DavePatriot77
Everything posted by DavePatriot77
  1. I'm having the same issue with my AR 152. I'm so frustrated as there does not seem to be a way to undo this. Using chirp inverted my power settings and also dropped the highest output down from almost 8 watts to about 6 watts. Has there been any progress on a solution to resolve this? And I understand this is a GMRS forum but I haven't seen this discussed in any other place. I would like to get to the bottom of this issue if anyone has any helpful solutions.
  2. Thank you for this post. I just experienced the same exact thing. I'm so pissed as there doesn't seem any way to undo this problem. Have you made any progress on figuring out a solution? Even baofang recommends using the UV5R setting to program the AR 152. It's even in the published documents. However if you use any chirp software to program the AR 152 it inverts the power settings and you lose about a watt and a half of maximum power output. I wish there was another forum that we could use to discuss this issue but this is the only place I saw any reference to this issue.
