WRTC928
4
Everything posted by WRTC928
Yeah, definitely best to not draw attention to yourself.
It did occur to me after reading some comments that because this is a NGP antenna in a NGP installation, perhaps the real difference is that the cable I changed to acts as a better counterpoise than the one I replaced. That could simply be a fluke, because I doubt either US or Chinese manufacturers give any significant thought to its characteristics as a counterpoise. Maybe they do, but I'd be a little surprised.
The stiffness of RG8 is specifically why RG8X was invented. It would be extremely difficult, if not impossible, to route LMR400 in most of the ways required in a vehicle.
Exactly. So, what's the point of telling me I'm using the "wrong" coax? I'm sure ladder line would give better results, but it won't fit through the holes in the floor of the back of the cab, to say nothing of going under the side bed rail, over the top of the front bed rail, down the front of the bed, under the cab, and back up through the hole in the floor. 15' is about as short as I can go and it has to be very flexible. I'm not aware of anything "better", but I'm open to suggestions.
I'll be civil to him when he stops being an ass.
That's nice to know, but LMR400 and Heliax aren't practical for vehicle installations.
I'll look at that for next time. In the meantime, I'm not having any more line loss than 99% of the installations out there. Less than most, in fact.
No, you illiterate. I specifically stated that it's an NGP antenna. But even an NGP antenna can often benefit from a good ground plane.
Every mag mount antenna and every NMO kit I've ever seen uses RG58. I'll bet all of you have at least one on one or more of your radios. RG58 is even more lossy than RG8X, so I'm mystified about why your installation is right and mine is wrong. If the dummy load isn't between your ears, tell me something I can use. Be Elmer, not Mr Magoo.
So what is the right cable? "You're doing it wrong" isn't helpful information. It might make you feel superior, but it sure as hell isn't going to save me any heartache or money.
It sounds like you're saying there's no point in testing. Any cable that's practical for a vehicle application will be lossy. RG58 is even worse, and that's what pretty much all mag mounts and NMO kits include. Are you suggesting we should use LMR400 for vehicle antennas? Why do you assume the antenna has an SWR of 10:1?
Alright, smart guy. How do you hook up an antenna without using a cable?
It is certainly interesting when you chart it that way. As you say, the SWR improved on the bands for which the antenna was not designed, but not on the bands for which it was designed. In effect, it made this antenna a little more broad-banded. Now I need to do some more testing. I'll try a couple of different antennas and maybe the dummy load test.
I was surprised. On the forums, there's always someone saying how Chinese coax is crap, real men only by USA cable, etc., but nobody's ever shown me the actual results. This is only one specific set of circumstances, and it's possible that if I had a good ground plane under the antenna, or a different antenna, the difference wouldn't be so obvious. Maybe in some cases, there's not enough difference to make a difference (RIP Paul Harrell), but in this case, it was worth the extra expense.
Which OEM antenna to use on the Baofeng UV-9G
WRTC928 replied to WSID730's question in Technical Discussion
IME, the general rule is that assuming both antennas are appropriate to the band I want to use, I'll get a bit more distance and clarity both rx and tx with the longer antenna. Often it isn't enough to matter, buy sometimes it's pretty noticeable. Individual radios may sometimes prefer one antenna over another for reasons I don't understand. That's kind of a long way around to say try them both under the same conditions and see what you get. -
I recently installed some NMO mounting points on my truck, but for a variety of reasons, I wasn't entirely satisfied with them and decided to do it over. For the first installation, I used generic Chinese RG8X coax, but this time I went with USA-made MPD digital RG8X. The first thing I noticed was that the MPD coax is much more flexible and easier to work with, but even more significant is what happened to my SWRs/Smith graphs. With the Chinese coax feeding a Diamond SG7900 Super Gainer NGP 2m/70cm dual-band antenna, the 2 meter and 70 centimeter bands were good, GMRS was in the "I can tolerate it if I don't use it too often" range and MURS (Which I've never used and could live without, but why not test it?) Started at 2.0:1 and went up from there. The first four pics are the sweeps of GMRS, 2m, 70cm, and MURS in that order with the Chinese coax and the last four are the same after changing to the MPD coax on the same antenna. 2m and 70cm remained good and even improved a little, but GMRS and MURS improved dramatically -- all the way to, "Yeah, that'll do." If (like me) you have sometimes wondered, "Does it really make that much difference?" the answer is yes, it does. The MPD ain't cheap at $2.34/foot, but I only needed 30 feet. TBH, even if I needed 100 ft, I'd buy the MPD. The difference is that obvious. As the saying goes, if you buy the best, you only cry once.
I don't know why it's so hard to teach people to do that. It drives me nuts. I tell them, "Push the button, THEN talk. Think of it like the second or so it takes your phone to dial a number. You're essentially doing the same thing." They smile and nod, then continue to start blowing from their pie-hole before they push the button.
Giving it to GMRS doesn't really solve anything except the question of what to do with it, but it doesn't really make sense to create a new class of license for that band. I suspect that if it were given to GMRS, users would divide up into "VHF GMRS" and "UHF GMRS" folks depending upon their needs or whims. And, of course, the occasional oddball would "need" to have two radios just because. Yes, repeaters would be expensive to build and maintain, but 6m AM simplex would be great for some things, especially with 50-100 watts. A lot of folks who now need a repeater to talk to the spouse unit from office to home could probably just go to 6m simplex. Farms and ranches that now use repeaters might be able to get rid of them. The easiest solution for the FCC would be to set some basic rules, toss it into the GMRS category, and say, "You figure it out. Or don't. Whatever."
Me too, and it works just fine.
That's awesome!
What radio are you using? If I understand correctly, you're in Death Valley or somewhere around there? Your geography is more favorable to radio waves than what most of us have. I can't get a hundred miles here even with my 63" antenna and 50 watt radio. But for my normal shopping trips, the little UT-72 works just fine.
Really, my point was that an antenna that does what you want is a "good" antenna. I see a lot of comments about how the UT-72 and UT-72G aren't very good antennas or even are "crap" because other antennas can be heard much further. That may be true -- I haven't tested it -- but the 72 and 72G have served perfectly well for what I've done. If I can't get the signal out with a UT-72, I can't get it out with any other 1/4 wave antenna either. Obviously, if I were offroad rather than in an urban/semi-rural setting, my results might be different. Today I was able to get a response from someone on a GMRS repeater 59 air miles away in my truck, but that antenna is 63" tall. You never get something for nothing.
I stand corrected. You are right.
Yep...not enough counterpoise.
It's not about strength. Steel will flex and even stretch under stress but fiberglass and carbon fiber won't; they crack instead.
