WSGQ856
114 profile views
WSGQ856's Achievements
  1. Hello WSGQ here and I'm having a problem with programming my GM-21 through CHIRP since it does not show up under radio selection. I have been told it is the UV5R since the configuration is the same..... or so ive been told. Does anyone have any ideas? Now using the tidradio wireless programmer i use the UV5G pro and it works, but i cant update my firmware using this method. Any help would be greatly appreciated
  2. WSGQ856, Tidradio sent a replacement due to power button not working, so with being said I am up and running and have all of my handhelds up and running. If anyone is thinking of using this wireless programmer please try it, it makes life easier when programming! Thank you again for everyone who replied to my dilemma I thought I was having WSGQ856 to for now
  3. Thanks for the responses, yeah that hard to see power button has been found and pressed, I guess I will try a replacement and hope for the best. Chirp usage might be the best way to continue my programming, again thank you for your responses! WSGQ856
  4. Hello everyone, I have a question about the Tidradio TD-BL-1 wireless programmer. I purchased one and charged it up and it will not power on, I emailed Tidradio customer support and no response. Does anyone use these to bypass the menus and make it easier to set up our radios? Has this happened to anyone, and if so does anyone have any suggestions, or even can point me in the right direction? I’m currently using the Baofeng GM21 radios Thanks WSGQ856
