It appears that when assembling my rooftop antenna system I can attach my coax lightening arrester either to the SO-239 of the antenna that will be clamped near the top of my 7-foot aluminum tubing mast or, I could splice it into the LMR-400 coax with an SO-239 and a PL-259 end near the bottom of the mast just before the coax enters the wall of the house. The base of the aluminum tubing mast will also have a ground wire attachment and both ground wires will be fixed to an 8-foot ground rod some 25-feet away, 4-feet out from the house. My question is ‘in which of these 2 locations should I install the coax lightening arrester’ regardless of what rigid antenna is at the top of the mast’ ?
