WSFF627
Everything posted by WSFF627
If the repeater is listed as "open" you do not need to request access. It really depends on how often a repeater owner checks their email and logs in to approve requests. There is little a repeater owner can do to prevent people from using a repeater with published tones. There are also radios capable of scanning the tone to gain access, GMRS repeaters really are not secure.
As lots have mentioned here Heliax is the ideal choice. However you need to decide how much you want to spend. LMR400 is cheapest, LMR600 is more expensive but loss wise more comparable to 1/2 Heliax. For your length the dB loss doesn't justify the cost of 7/8 Heliax in my opinion. Yes the LRM types risk noise in full duplex operation, however that's more prevalent in wattages much higher than 50 watts and when there is a bunch of cable flex. I ran a test on a 100 watt 70cm HAM repeater for a while on 65 feet of LMR600 and didn't see a noise issue. Yes 400 will work but is not the best choice due to higher loss. Everyone thinks about TX and power out loss, but not many talk about RX loss, and a pre-amp cant do something for what never makes it to it. In high RF environments or with poor filtering, or a combination of both, they can do more harm than good. If your going to try one, get if from AdvancedReceiver.com I have several of them, they work great, and if you have a service monitor and the knowledge, can adjust them. Large Heliax is the best performing choice, and the most expensive, the connectors alone are $35 each. LMR600 is a good economical and good performing choice. Its actually in service in a lot of commercial setups on short runs, so is LMR400. But you wont find either going up a commercial tower due to loss and the noise issue at high wattage. Andrews and Times Microwave also offer grounding kits for LMR600. I recommend grounding the cable shield as well as a good quality (not a cheap amazon) lightning arrestor. A good one will run you $100 or so. Check repeaterbuilder.com It has lots of good info and a copy of the Motorola site standards, which you may find very helpful. I own and operate a GMRS repeater with a 60 mile radius as well as a 70cm DMR HAM repeater that can go farther (both have site elevation to their advantage, they are high). I've also put together other large footprint repeaters at commercial sites.
I'm wondering what coax your using. I'd recommend 7/8 heliax or similar due to the length involved. You can often find some good used cable from radio shops that they have removed from service on a commercial site. Also run a jumper from the main feedline to the antenna to allow for movement between the two in order to take stress off the connectors. A loose connection will cause desense and drive you nuts. I'd also recommend a RX preamp from Advanced Receiver. I have a handful of them and they make a big difference. To your comment about getting above the trees, your right on point there, just getting above the tree line will make a big positive improvement. Also, ground the coax toward the lower end of the tower above where it bends to go into your repeater location and take the ground straight down towards the ground to a proper ground rod. The lightning arrestor should be located just outside the building. Repeater Builder has a section on Motorola site standards that is helpful. Here is a site you can model your coverage on https://www.ve2dbe.com/english1.html
Lots of good options have been discussed here. All work relatively well. For a base radio, pretty much any 12 volt battery will work. Keep in mind that TX power can vary greatly with battery voltage. 1-2 volts can mean the difference between 35 watts and 50 watts, depending on the radio. Granted, this is only a couple of dB, but those may be the dB's you need. Battery power for base radios can be pretty easy, and all the options above are pretty good and will work for your application. Repeaters are a different story, while you control the use of your radio, repeater use can vary quite a bit and be a lot more demanding. A typical radio is built to TX with a 20% duty cycle, a repeater is built for a 100% TX duty cycle. I run a 50 watt GMRS repeater with a large footprint, a 100 watt 70cm HAM repeater, and a remote RX station for a very large 70cm HAM repeater out of my "repeater shack". The GMRS and remote RX are Kenwood TKRs which run on 13.8vdc, the GMRS has an amp for duty cycle at 100%, and both are running pre-amps at 13.8vdc. The power supply for them is a Astron 50amp with built in battery backup. Its battery backup is 12vdc. The 100 watt 70cm repeater is Motorola MTR3000 (100% duty cycle at 100 watts), which requires 28vdc and a battery reverting charger (its also equipped with a pre-amp that its built in supply handles). Battery capacity is sized to run the repeaters under full power with moderate usage for at least 24 hours before they have to transfer to an inverter generator (regular alternator generators produce very dirty power). Its essential the 70cm remote RX stays on the air because its part of the SKWARN network. The other HAM repeater may join it in SKYWARN service in the future, likely in digital or mixed mode. Its also pretty important the GMRS repeater stays on the air because users have expressed they want and or need it for emergency comms with family and friends. Currently I have to transfer power to generator manually, but I'm planning an auto start and ATS project for that so its all auto. The best power / battery backup option for you is one that works for you and costs what your willing to spend on it.
Just tuned one today. Confirmed at 0.6dB insertion loss on the service monitor. https://www.bridgecomsystems.com/products/4-cavity-txrx-350w-uhf-duplexer?currency=USD&variant=41431623172261&utm_source=google&utm_medium=cpc&utm_campaign=Google Shopping&stkn=d6eaad281b8a&utm_source=Google_Ads&utm_medium=Duplexers_Shopping&utm_campaign=Duplexers_Shopping_Campaign&tw_source=google&tw_adid=664925858611&tw_campaign=20342176746&gad_source=1&gclid=Cj0KCQiAlbW-BhCMARIsADnwasqZg1QSmh5e4yADfPU4xLrwHKAbWB9BFk2ZIo6jHxDCf44DJQ4fp-AaAj7BEALw_wcB
Thats correct. TXRX duplexers have the lowest loss of any duplexer I have seen. 0.6dB, some loss, yes, you should see 50w in and 41-43w out of the duplexer. A lot less loss on the RX path, which in my opinion is more important than TX power.
Sorry for being short,, only got a sec... Bridgecom not bad, set tx at legal 50w out of the rpt. A good TXRX 4 can 350 watt duplexer, 0.6dB insertion loss will offer the best post duplexer wattage. Obvioulsy dont forget loss is a two way street.. Advanced Receiver makes nice pre amps. I run them on all my projects.
Nice!! That's quite a lot of feedline. Doesn't surprise me. All probably using the same type of feedline. 2M VHF doesn't loose nearly as much in the line as 70cm UHF. GMRS (UHF not far from 70cm, as I'm sure you know quite well) with 500 +/- less feedline. Any pre amp will also play a part on the RX side. For the sake of argument lets assume the tower is using Heliax LDF6-50 1-1/4 inch feedline. Feedline loss only, in addition to any combiner or duplexer, etc. loss. Rough numbers only. VHF at 900 feet is about 2.89 dB loss (125w TX,48% power loss) UHF at 900 feet is about 5.27 dB loss (125w TX, 70% power loss) GMRS UHF at 400 feet is 2.44 dB loss (50w TX, 43% power loss)
Line of site theoretical vs practical, in theory in space with nothing to attenuate the signal, very, very far. ISS contacts happen all the time with 5w or less. In practical application on earth, it boils down to terrain, geology, height above average terrain, occasionally ducting, and the equipment in use. There are simply too many variables in play to say it will go X miles. All transceivers and repeaters are not created equal. My Motorola's have the best receivers, my Baofeng's the worst. A repeaters performance varies greatly based on its antenna height above average terrain, antenna type, quality and gain, overall losses from feedline, duplexer and jumpers, if there is an RX pre amp, RF environment (other RF at repeater site) etc. I can have a conversation on my repeater at 30 miles from some locations with a 4 watt Motorola portable. Standing in that same spot, a 5 watt, $15 Baofeng sometimes works, sometimes does not. I can also move 10 feet and it will no longer work.
I understand what your trying to do, its a cool idea and I sincerely hope it works out for you. However, I believe the FCC is going to tell you you cant do it because it is a clear violation of the rules as written. POC uses the Cell telephone / data network. It is a network in every sense of the word. As I and others have stated before, yes you can connect a repeater for remote control of the repeater, you cant do it to carry messages / voice comms. In any case, please keep us posted with the FCCs answer. This is and has been a good conversation.
Please go read the Law. Its clear you cant operate on digital modes on GMRS. Its clear you cant connect GMRS to another network for comms. I don't need an attorney to take it to court to show its illegal, its written in the law. This horse is dead. If you don't want to read the law or are looking for bits and pieces to justify what you want to do, go hire an attorney for a few hundred to review it and give you a legal opinion. Or do it anyway and end up on the FCC enforcement radar and risk it. Telling people what your doing and selling them a product or service that is not legal opens you up to liability. Hire an attorney and get a legal opinion from them.
I'm not saying it wouldn't be a win, but currently what your doing is not legal. Also, it sounds a lot like your talking about DMR talk groups on GMRS and taking a page out of the HAM / DMR / Brandmeister playbook and marketing it. All of which is available on the HAM bands for free, including linked and worldwide repeater network, hotspots, etc. as I'm sure you know. Now I'm knocking you for trying this, cant really fault you for it. But at the end of the day, GMRS does not allow it and does not have the bandwidth other radio services do, like HAM, which is easily accessible to the public.
"remote control" and conveying "messages" are not the same thing as defined by the law and FCC. Remote control would be activating / deactivating transmitting function of the station, changing the channel, tone, etc. messages, wireline control link - every network everywhere travels along a wireline All cell towers are on a fiber and copper wire network.
From your website... Digital modes are not permitted in GMRS. "Other networks" is the internet, and literally any other network... LTE networks included. The law: § 95.1749 GMRS network connection. Operation of a GMRS station with a telephone connection is prohibited, as in § 95.349. GMRS repeater, base and fixed stations, however, may be connected to the public switched network or other networks for the sole purpose of operation by remote control pursuant to § 95.1745. § 95.1731 Permissible GMRS uses. The operator of a GMRS station may use that station for two-way plain language voice communications with other GMRS stations and with FRS units concerning personal or business activities. (d) Digital data. GMRS hand-held portable units may transmit digital data containing location information, or requesting location information from one or more other GMRS or FRS units, or containing a brief text message to another specific GMRS or FRS unit 95.1733 Prohibited GMRS uses. (8) Messages which are both conveyed by a wireline control link and transmitted by a GMRS station;
X2 BoxCar. I'm also quite curious about this.... you website clearly states its connecting the GMRS repeater to an LTE network. FCC Rules state "Linking multiple repeaters to enable a repeater outside the communications range of the handheld or mobile device to retransmit messages violates sections 95.1733(a)(8) and 95.1749 of the Commission’s rules, and potentially other rules in 47 C.F.R. Repeaters may be connected to the telephone network or other networks only for purposes of remote control of a GMRS station, not for carrying communication signals."
I normally don't respond to posts or spend a bunch of time on forums. I found this interesting with lots of differing opinions and some good points. My thoughts on radio and its use are shaped by a carrier in public safety, emergency management, and my personal use of Marine VHF, GMRS and HAM, within licensure guidelines. The FCC states "95.1703 Definitions, GMRS. General Mobile Radio Service (GMRS). A mobile two-way voice communication service, with limited data applications, for facilitating activities of individual licensees and their family members, including, but not limited to, voluntary provision of assistance to the public during emergencies and natural disasters." As mentioned, I have both GMRS and HAM licenses. I also own a local GMRS repeater that has a large footprint, and am involved in HAM repeater systems that are part of the SKYWARN network. No, GMRS was never meant to be HAM. But all things evolve over time, it will not become HAM (nothing will become HAM, it is literally an experimental license that allows HAMs to do many, many things), but its use has and will evolve (grandfathered licenses for example) just like CB radio did. In my opinion, GMRS has some distinct advantages over HAM. The biggest being that once license covers a family. Repeater linking is not allowed in GMRS, so that keeps comms more local. A big benefit to GMRS and GMRS repeaters in particular, is the ability to provide alternate and emergency comms for families and friends. Most of the people who want access to my repeater specify they want it for emergency use to communicate with family and friends. Something a lot of people don't realize about cell phone service. Cell providers, and really all of telecom, are not required to provide long term emergency power for their sites or nodes. Most only have battery backup that doesn't last very long. My area gets hit with some severe weather once a year that causes widespread outages due to power and telecom lines being down. The first thing that happens is the cell towers get loaded up and bandwidth drops. If you have a cell provider that is not a big company that owns its own network, you are the first to get dropped from the network / site. Most people also don't realize that most "landline" phones are now VIOP. When the node goes down because its batteries are dead, so is you phone and internet (assuming you have power). As soon as the cell site without a generator looses it battery backup, its off the air and your cell is out. This can last for days. In contrast, the "big" repeater sites, both HAM and GMRS, are on UPS and gen power. My GMRS repeater can run a minimum of 24 hours with moderate use before I need to plug it into the generator. All the HAM sites I'm familiar with are the same way and are usually on commercial towers with gen backup. In order to use radio for emergency comms, you need to be familiar with radio and be fluent in its use. You need to know your radios work, you need to know the repeaters you programmed a year ago are on the air, and you need to know where you can use them from and who you can communicate with on them. You also need to have a plan for using radio to communicate when cells and landlines are down. Radio checks, general conversation, and rag chewing on repeaters helps ensure this.
