Savage
Everything posted by Savage
  1. Thanks guys, I'm convinced and will mount externally. When you say "properly protect" are you referring to grounding? What I plan on doing (and please help me if this is not good...) is putting one of these inline (https://www.amazon.com/dp/B01LYK5TU5/?coliid=I1N5MV9ORTQK7L&colid=WG94VUDFRLCV&psc=1&ref_=lv_ov_lig_dp_it) and getting a grounding rod and wire to ground. Really wish I didn't need to do this though. Without the grounding wire on the side of the house, this would be clean straight from the antenna and into the attic vent, down into the room.
  2. Alright - I have everything but the cable (and lightning protection components)... I know there's probably variables preventing a straight answer, but thinking about this, there's a lot of simplicity (and probably more safety, for me) mounting this Tram antenna in my attic. The question being, is the extra effort, etc. worth mounting on the exterior? Will there be a noticeable difference in performance? Just to give a view, and don't laugh because the screenshot is from some landscaping software I use, but I've marked the two locations in this graphic. One is mounted to the fascia board and the other is just inside the wall, in the attic, about 5' lower than it would be on the fascia. The radio will be in the room directly below this.
  3. In typical newb fashion, I already bought a radio (TK8360H), cable and the software, but I've now saved this seller for future use. Appreciate all of the recommendations on this seller.
  4. How does the kenwood tk-8360H compare to the TK-8180? I ask because most of the 8180's on ebay look pretty beat. The 8360 is a little more money but they seem to be in better shape. Any opinion on whether this is a good deal or better to buy a radio only and the accessories separately? https://www.ebay.com/itm/KENWOOD-TK-8360HU-1-UHF-450-520MHZ-40-WATTS-128-CH-RADIO-READY-TO-INSTALL/174309748834?hash=item2895abb062:g:rqoAAOSw3iRe3UbF or https://www.ebay.com/itm/Kenwood-TK-8360HU-TK8360HU-UHF-450-520-Mhz-128-Ch-40-Watts/123707020571?epid=17030930635&hash=item1ccd83551b:g:MdQAAOSwHN9cmTVt Or neither? Then I need software and cable... would have to figure that out.
  5. The more I look at this the more I think it's probably not a big deal to drive a grounding rod in. I can dig past the gas pipe and since that's beyond all of the utility service entrances, all I have to avoid is that gas pipe, water and low voltage wire. Looks like Home Depot has a 5/8" rod, clamps and 8 gauge copper wire (can the ground be open (i.e. without the plastic covering?).
  6. Thanks for all of the input - the electrical panel is on the side of the house so perhaps I'm back to doing it there since whether I use a rod or panel, those options only exist on this particular side of the house unless I want to do a longer run from the opposite side of the house but that means a much longer coax cable (and greater visibility of the antenna).
  7. Ah yes, there's some copper coming out of the garage and into the ground and this seems to be jogging my fuzzy memory (I think you're right). One thing I do know is I did not pull out anything deep. I think that copper actually ends up as PVC to my garden. Is that copper pipe a feasible grounding point? There's also a gas line and that runs in that same small channel to my pool heater so if I ended up needing to drive something into the dirt, I'd have to dig and make sure I avoid everything I've run there.
  8. Didn't even think about that - it's definitely on top of a metal mesh. If I can get convinced of the grounding safety I'll just place it on the exterior. I don't have it anymore (cut the cord), but when I had satellite TV, I think their ground looked something like 12 gauge wire down to the side yard but I can't recall whether they had it attached to the metal gas pipe (thinking about it, wouldn't that be a bad idea?) or if I removed a post hammered into the dirt when I took everything out.
  9. I'm in a wood framed, asphalt shingle house so no stone or brick although the exterior does have stucco. In the end, if the attic really isn't a deterrent for lightning strikes there's probably no sense in me putting it there but as usual, the opinions are all over the place. We have an HOA but it's a skeleton HOA (houses from the late 60's) and they really only keep up the club/pool/tennis courts and do no enforcements of any of the minimal rules that nobody has probably read in 30 years. That said, I'm not going to get anywhere near 20 feet in fact I'm planning on screwing it into the fascia board (I think there's another name for it - the wood that frames the eaves) so it will be about 5' above the crest (unless I go with the attic). I figure that's better than an antenna sitting in the room with me.
  10. Now we’re well over my head and reading some of the info at the arrl.org link has me thinking this is too complicated. The fortunate thing is I’m in Southern California (fortunate... for the weather) and we rarely have lightning at all. Question about the attic - I probably have enough headroom to stand this up in the attic. Is the attic perhaps a better option, similar to what you’ve done? is the attic a compromise?
  11. I found the Tram for a really good price so bought it. Since I pretty much know nothing about the connectors and such other than what you've mentioned I'll wait until it arrives and I am certain about the mounting spot before I grab the rest of what I need. Looking around the house, I think the peak on the back of the house might be a better place so it's not visible at all from the street whereas on the side it will have some visibility at certain angles and at the back, it's still not that far from the room.
  12. Admittedly, I was hoping you were going to say the other is better, since it’s less costly. the place I can mount is almost 16’ up so I won’t be moving the antenna back and forth. Alright, I guess I need to grab one of those, 25’ or so of cable and drill some holes. My wife is going to love this, though she ought to be used to it after all these years.
  13. That would certainly be easy to install. would you recommend that over these? Keeping in mind I know nothing of antennas, they just seem... bigger. https://shop.mygmrs.com/collections/antennas/products/retevis-ma02-vhf-uhf-omnidirectional-fiberglass-base-station-antenna https://shop.mygmrs.com/collections/antennas/products/retevis-ma01-uhf-omnidirectional-base-station-antenna https://shop.mygmrs.com/collections/antennas/products/tram-1486-uhf-fiberglass-base-antenna
  14. Alright - any advise on an antenna and cable for a base station? The peak of my roof is almost right above the room I'll put the radio so I have an easy mounting point where I can screw into wood with a bracket and run the cable through the attic, out the vent to the antenna. I'm not looking to break the bank on this - if I find myself addicted to radio I can always upgrade later plus I'll just be using the MXT115 for now (power supply will be here next week).
  15. Dang, you all learned me a few things today. I better stop now since I learned more than my daily quota of 1. Many thanks!
  16. LOL, exactly. Lemme try again. If using channel 15 (462.55) without either type of code, I'll hear everyone communicating on ch 15 whether they're using a code or not. If using channel 15 (462.55) with DCS code 25, I'll hear only others on the same channel using DCS code 25. Others using ch 15 without a code or if using ch15 with the same code will also hear the communications. Swing and a miss or I got it?
  17. Gotcha - so if using channel 15 (462.55) without either type of code, you will only hear those on that channel who also are using no code? And for example, if using channel 15 (462.55) with DCS code 25, you will hear only those communicating on that same channel using that same code? That makes a lot more sense to me if that's right.
  18. I want to make sure I understand this correctly. If understood something I read, when on a channel without any code, you can hear chatter from everyone using that channel even if they're using codes. Is that right? If that's right, is what you're saying to clear the code before using that channel for communications to make sure others aren't using the channel (without a code), otherwise I'd be talking over them? Something about that doesn't seem right... please clue me in.
  19. Well, there's my learnin' for the day! Thank you very much. LOL - I've heard some solo ranting too but I think it was one of the two same guys. Thank you for the info.
  20. I'll try not to be a COMPLETELY typical newb... but, taking the advice of posts on this forum, I'm doing "a lot of listening" with the handheld (GXT1000) to hear what's happening on the air. There's not a lot going on but two channels do have traffic with one of them fairly often with the two same guys. They talk about a lot of stuff, for example, Betty Crocker cake mix, chit chat during baseball games, some random humming and singing into the radio, misc. cursing and talks about "people" plus some politics. Sometimes it's not exactly family friendly (from my perspective)... all this is to say, it really puts a dent in my scanning channels because this channel is where it stops much of the time. SOOOOOOOOOOOOOOOOOOOOO... how do you all handle this? Are "better" radios that have software to control them capable of turning some channels off from scanning? Is the Midland capable and I just haven't found the instructions to do it? Do I need to just get over it and every time it hits that channel, press a button to rescan until it comes back to that channel, rinse and repeat? I've read the FCC guidelines by the way so I understand that they're not exactly following it but understand the practicality of radio use, I don't plan on being the GMRS police or disruptive to their use of the channel and particularly, don't plan on being "that newb." Looking for frank advice and if "get over it and press the freaking button" is the answer, I'll probably just do less scanning and get over it. Thanks peeps.
  21. All Greek to me but I went ahead and ordered it. Now... an antenna and cable. Hmmmmmmmmmmmmmmmmmmmmmmmm... and of course another thread already has me wanting to try a Kenwood TK-8180 and I haven't even put power to my Midland. I'm rationalizing though - the Midland could go in my wife's car.
  22. I'm very much a power dummy... so I'd grab that PSU and (figure out where) attach this to it? I'm wanting to keep the wiring intact on the Midland so I can still easily throw it in my car and use aux power. https://www.amazon.com/dp/B00G8WLW2Y/?coliid=IG4PJT5HK4K7A&colid=3SGB1VHXDD1KT&psc=1&ref_=lv_ov_lig_dp_it
  23. Here's a couple key pieces on this topic. Power Adapter to connect power to the Midland
  24. After posting about how to do an install of a mobile (Midland MXT115) in a car I realized that I'm so new to this that I should wait to do any hole cutting and cable running in my car, particularly since I spend about 30 minutes every week in it now with covid era work from home, and setup the radio in my house. https://forums.mygmrs.com/topic/2103-installationmounting-in-vehicle/ Some great information in the previous thread on the power supply, etc... and now I'm wondering about running antenna cable from the room to the roof, what antenna, etc. so am starting a new thread as suggested. Here we go...
