jameschung
jameschung's Achievements
Newbie
Newbie (1/14)
Reputation
  1. Thank you jmoylan69 for responding. I am ashamed to admit that my handheld unit is a cheap Motorola 1.5w walkie talkie. I can select the channel that is pre-programmed RX 462.5500 and TX 467.5500. And I can also set the code to 141.3 Hz. Both units hear the repeater announcement. Then if I use handheld A to transmit, both units hear the response from the response. But it's just a screech and the beep. Both units hear it. But not the actual voice comm. I hope I'm making sense. Since both device can hear the initial announcement and also trigger that...they are accessing the repeater properly. It's the actual communication following the announcement that is without the voice.
  2. Hi, I have the similar issue as tcushman. My local repeater is listed on mygmrs and on their website (BARN-R1) as an open system. Travel Tone: YesORI: NoApprx. Range: 85 MilesOutput: 462.550 MHz 141.3 HzInput: 467.550 MHz 141.3 Hz I can trigger the repeater because both handheld units can hear the "announcement." But the units can't talk nor listen to each other afterwards. Attached is the audio recording. https://youtu.be/qWa8aGMxUVQ Is there "one" thing I'm forgetting? Thank you in advance.
