WRMB269
Everything posted by WRMB269
  1. Welcome to GMRS
  2. Mount https://www.amazon.com/Skywalker-Signature-45-60in-Adjustable-Mount/dp/B009P78R68/ref=sr_1_1_sspa?crid=2XI9IJ7I0LN9T&keywords=eve+antenna+mount&qid=1651157149&s=electronics&sprefix=eve+antenna+mount%2Celectronics%2C76&sr=1-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyVTFFTzdQRFo5STNUJmVuY3J5cHRlZElkPUEwMzc4OTEwVjM5QTJOMlI0MVQwJmVuY3J5cHRlZEFkSWQ9QTAxMDM5MzgyWDVUTENGNkI5STFOJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ== Coax LMR240UF for runs shorter than 25ft LMR400UF for anything over 25FT Example of LMR240UF jumper cost with connectors look around for best price! https://www.ebay.com/itm/173767279461?hash=item2875564365:g:NbIAAOSwMSRfSTbj Example of LMR400UF jumper cost with connectors look around for best price! https://www.ebay.com/itm/184232597543?hash=item2ae51e5827:g:KDEAAOSwlsVegeNH Antenna (don't get obsessed with gain claims) The most important factor that will effect performance is how high the antenna is get it as high as you can!!!!!!!! Option 1 (ready to install) https://www.amazon.com/HP-50-N-460-470-GMRS-Band-Antenna/dp/B08N17RRKT/ref=sr_1_3?keywords=gmrs+base+antenna&qid=1651157772&s=electronics&sprefix=gmrs+base%2Celectronics%2C95&sr=1-3 Option 2 (cheaper but need to use your own pvc pipe) https://www.kbcubed.com/DBJ-UHF-5dB-GMRS-Antenna-by-Ed-Fong-p379488596 Hope this helps you get started and good luck welcome to GMRS !
  3. Mount https://www.amazon.com/Skywalker-Signature-45-60in-Adjustable-Mount/dp/B009P78R68/ref=sr_1_1_sspa?crid=2XI9IJ7I0LN9T&keywords=eve+antenna+mount&qid=1651157149&s=electronics&sprefix=eve+antenna+mount%2Celectronics%2C76&sr=1-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyVTFFTzdQRFo5STNUJmVuY3J5cHRlZElkPUEwMzc4OTEwVjM5QTJOMlI0MVQwJmVuY3J5cHRlZEFkSWQ9QTAxMDM5MzgyWDVUTENGNkI5STFOJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ== Coax LMR240UF for runs shorter than 25ft LMR400UF for anything over 25FT Example of LMR240UF jumper cost with connectors look around for best price! https://www.ebay.com/itm/173767279461?hash=item2875564365:g:NbIAAOSwMSRfSTbj Example of LMR400UF jumper cost with connectors look around for best price! https://www.ebay.com/itm/184232597543?hash=item2ae51e5827:g:KDEAAOSwlsVegeNH Antenna (don't get obsessed with gain claims) The most important factor that will effect performance is how high the antenna is get it as high as you can!!!!!!!! Option 1 (ready to install) https://www.amazon.com/HP-50-N-460-470-GMRS-Band-Antenna/dp/B08N17RRKT/ref=sr_1_3?keywords=gmrs+base+antenna&qid=1651157772&s=electronics&sprefix=gmrs+base%2Celectronics%2C95&sr=1-3 Option 2 (cheaper but need to use your own pvc pipe) https://www.kbcubed.com/DBJ-UHF-5dB-GMRS-Antenna-by-Ed-Fong-p379488596 Hope this helps you get started and good luck welcome to GMRS !
  4. Another way to look at Coax loss, I have always lost guys talking about dB loss and this chart also includes Watts loss and brings the point home PS 70cm would be your reference for GMRS performance! EVIL COAX CHART FOR 2M & 70CM.pdf
  5. my favorite RF reference book is (do not buy it from link way to expensive I found one for $20 but thought it was worth sharing. Radio Handbook, Twenty Third Edition 23rd Edition by William Orr (Author) https://www.amazon.com/Radio-Handbook-Twenty-Third-William/dp/0750699477
