dhardin53
About dhardin53
  • Birthday August 11
    Dan Hardin
    Illinois
  • Interests
    GMRS for my retirement enjoyment and side business.
    At age 18 I had an FCC "CB" license, KNG5645. In fact, that was the year the FCC stopped issuing CB licenses I got my money returned.
1133 profile views
dhardin53's Achievements
  1. Our phones are Qi 2 and above. My car and truck have high-output charging ports. These will not change any of my many USB-C radios. Yes, around the house, I have several dedicated chargers for the new USB-C radios that work well. However, we also have many Qi2.2 chargers for our phones. This small chip enables high-output chargers to work with the radios, allowing me to charge at any time, anywhere.
  2. Not all USB-C are compatible. The problem is that high Amp chargers will not charge most of today HT's. Here is the fix. Get several; they are cheap. I got some clear wire shrink wrap to protect them.
  3. About to finish my 9-element Yagi. Two things you might check, I had a similar issue. Your high movement for me anyway was when making the N connection to the Gamma feed line, I got the center pin connector too hot and the installation holding the pin became weak. This causes the N connector to not have a secure connection if I move the antenna. It is always something small. I hope you can check this out and solve your issues. It did for me.
  4. Ok, "Packet Mode" and GMRS "Simplex repeaters" a two different animals. Your correct with the MURS channels and FRS are channels have many many limits within GMRS radios. So a simplex repeater operating on just GMRS channels only should be ok. GMRS rules state "Duplex repeater" have dedicated channels using to different frequencies. Simplex is technically a single channel being repeater But only using one channel. Current example; the new Btech pro is able to transmit Data (packet information). But NOT on GMRS dedicated repeater channels, as well and NOT on FMS dedicated channels.
  5. I have a GMRS license, I intend to follow the FCC rules as written . The family or extended family only use sounds very cut and dried. In reality In my limited GMRS motoring in my small portion of central Illinois. Even now with a temporary roof mount increasing my monotiling foot print, and mobile monitoring the 50 miles around me. Not that much is going on. I have 2 repeaters within 40 line of sight form me. The activity is nearly none existent. I have never heard anyone using repeater channels in simplex on a repeater pair. I guess my point is extended family for this area has become you/your family and more often close people in your party are using the GMRS in a respectable manner. My location 90% of my monitoring are independent small business communicating with there co-works/closely-knit family. Myself I see noting wrong. Some will disagree, In short "When in Rome do as Romans"
  6. Narrow it down some yesterday. Not a 100% but I will soon. It is a good possibility a "Lamb wave" or some type of ultrasonic testing. Go figure.
  7. Interesting insight, thank you so much. Interesting maybe not related. Sunday night around midnight one leg of the 200 amp breaker failed. After 20 minutes of investigating found one leg at the meter/main breaker and found it. I'm sure it is just a weak breaker and will be replaced today, this happened last year. Just wiggling the old breaker I head something inside the breaker ping sound the then returned the load to normal. Still working today but this breaker is 40 years old and if this is a utility componiee problem that may have effaced the leg going to my house it is a good time to replace it. But them anagen i don't feel my weak old breaker is it issues. but on never knows. Great weather today to get out and program this exact frequency in the hand-held and do just as you said. Would be a nice time to have a small foxhunt mini beam. http://www.arrl.org/direction-finding Thaks again, a little guidance means a lot. WROQ912
  8. Been doing some investigation work. found the reason why my KG935G when in scan mode keeps geting a spick and stops scanning. My personal wirless weather station works on 915mHz, killing all Wi-Fi and LED lights, and still pulsing. The neighbor next door has a security gate topically use 316 and 415 MHz, Plane a wlaking over there tomarrow and see if signal increases. Sound a lot like a beacon posable from the local county airport one mile away. will take a drive over there as well. Wireless gas meter and electric meter I believe is in the 800 rang? the water meter has some type of Automated Meter Reading (AMR) of sending device as well. Not sure of its frequency. I think it is a drive my system or meatier readings. Fire up my HDSDR dongle and found this. Sound is not great but there is a click at the end of each burst. Any suggestions. 20220313_235437.mp4
  9. I have read that Midlands "ghost" will have a better SWR if one mounts it closet to the corner of the roof or trunk. Try moving it around and see if there is a difference.
  10. Two months of GMRS scanning channels as I drive. 2 framers applying anhydrous in a field, Ameren service men using a bucket-lift truck and a guy on the ground as a spotter. A large solar farm being built in our area heavy equipment operator getting guidance from ground crew. Local auto wrecker auction house that sells your insurance totaled automobiles, once a week the get busy before the Thursday morning auction coronating income and outgoing wreckers of where to go on the lot. Old Franklin Life building and a Crain operator on the ground, 15 stories up a guy rigging for removing cap stones, they removed 36.000 lb. before noon. Here in central IL it is rather flat land, there are 3 repeaters close. The closes is 35 miles as the crow flies. My HT and micro mobile I have not a peep from them. I did not get into GMRS to talk to only but the familty business I am working with. Yes the wife for the fist time was HT to me mobile. Our camping/winter snow-bird was abruptly postponed when the wife had emergency surgery. I still plane on more an better communication equipment in the future.
  11. 30 day ago I started this post. It saddens me to see the amount of discourse it has provoked. I don't mind a spirited discussion, I don't have a strong opinion with this topic as some have expressed. A simple goal for licensed GMRS to be able to connect with others GMRS travelers should NOT be such a imposable hurtle. But it appear to be the case. FCC rule is that GNRS is intended for general mobile radio using one license call sign for family and extended family. I see no rule stopping two Licensed GMRS operators making casual contact. So why are we so divided? If you don't wish to participate in a general Consensus then don't. Just don't. Stop trying impede others from ones freedom to associate. This topic has got off in the weeds many times I guess that go with the "world of Forums" I most of all would be considered weak in the written word/text and being miss understood. I get that, I have seen many well expressed points of view. Many good people looking for a command good as well. I have read every post and come to a conclusion. Some just don't want to play well with others. I am sorry to say I will never make this mistake again.
  12. I have plenty of PL259 connectors around, the coax is good the rubber on the bottom of the mag mount is a bit crack and ages. Liquid rubber sealant might fix that. Then cut me up some old stainless antenna for a whip and tuned. Then fabricate some brass 1/4 20 bolt and drill a hole for the steel and braze them together. I have a better than 80% change of repurpose this. I just got a Browning 3db mag mount for the wife's car. (Not real happy with the first test run with it), hoping to get the KG935G with a roof top. This little Cell-booster might work for other road trips use. I need some winter project's to keep busy, The wife just got out of hospital so I need to be close to home for a good while.
  13. I agree kb2ztx, just going through 30 years of stored radio history. out with the old in with the new.
  14. Thank you, yes my web search looked a lot like the Wilson cell boosters. What little I know the communication componiee that he was working with had several issues and guess this antenna was something close but in all his service and radio work performance was poor. I think the guy used what ever he had to keep the acount. This is at least 10 to 12 years old. I can't see the guy i got i from was using Wilson cell boosters at the time. The TNC connector leads me think Cell booster.
  15. 12 inch tall, top of the mag mount to top of antenna, RG59 to a TNC connector. The logo at the base looks like a whale. I'm guessing I got this when I did some work for the guy that gave it to me. I help changed out his business band system? Just not sure, like to know what frequency it is designed for. Thanks in advances.
