Thanks again guys.
The flagpole is fiberglass and collapses. It's only up when I'm parked someplace that gets a breeze, usually the beach.
I'm looking at getting gmrs to go along with my cb as an alternative when needed. Mobile use unless needed while stopped, so not really a base station.
What do you think about putting a pvc pipe on the back near flagpole that I could raise/lower a few feet for mobile/base use. Running the cable down the inside of pipe, under truck to cab and inside to radio. This would of course require a way to disconnect for when the camper comes off the truck.
Looking on line what are you thoughts here:
Just an arbitrary site I found via google
https://www.arcantenna.com/collections/gmrs-antennas-nmo-mounts
from that site, would this be a good choice?
https://www.arcantenna.com/products/laird-antenex-fg4500-450-470-mhz-5-dbd-7-15-dbi-outdoor-fiberglass-omni-base-station-antenna-with-n-female-connector
looks like I'd need this to mount the above
https://www.arcantenna.com/products/rfmax-rosahdm1-heavy-duty-bracket-wall-or-mast-mount-for-omnidirectional-base-station-fiberglass-stick-antennas
other possibilities,
https://www.arcantenna.com/products/base-loaded-chrome-coil-antenna-for-gmrs-rbc-450-2-s
or this, not sure how it compares to the above.
https://www.arcantenna.com/products/gmrs-mobile-vehicular-antenna-base-loaded-chrome-coil-rugged-no-ground-plane-required-with-spring-rbc-450-5-ns#description
