StepUp2TheMyke
Everything posted by StepUp2TheMyke
  1. I have found a particular issue with this radio. It seems if you leave the lower channels with high power programmed in memory, the radio will automatically switch to low to be FCC compliant. The time it takes the radio to automatically switch to low power is the cause of the delayed audio output on transmit. It seems to affect other channels if left with high power programming in the lower channels. Once again poor firmware problems.
  2. I have found a particular issue with this radio. It seems if you leave the lower channels with high power programmed in memory, the radio will automatically switch to low to be FCC compliant. The time it takes the radio to automatically switch to low power is the cause of the delayed audio output on transmit. It seems to affect other channels if left with high power programming in the lower channels. Once again poor firmware problems.
  3. There is no mic gain setting on this radio. ?
  4. I have found a particular issue with this radio. It seems if you leave the lower channels with high power programmed in memory, the radio will automatically switch to low to be FCC compliant. The time it takes the radio to automatically switch to low power is the cause of the delayed audio output on transmit. It seems to affect other channels if left with high power programming in the lower channels. Once again poor firmware problems.
  5. I have the same modulation problem especially on the lower frequencies. While poking around I decided to get rid of that noisy fan....
