oscarach
oscarach's Achievements
  1. The 1/4 wave did make a big difference. Channel 1 & 22 (low power) SWR is now 1.07 car running 1.03 car not running. Channel 22 (high power) SWR is now 1.72 car running 1.65 car not running.
  2. Thanks for the advice, I have ordered a 1/4 wave antenna and will see how that works. I have some aluminum plate laying around and could make a 12"x18" plate bolted to the two load bars and mount the antenna in the middle of that, I assume that would give me a better ground plane. If that would help the antenna work better then a question is does that plate need to be bonded to a vehicle chassis ground? I have seen some of the HAM guys on the off-road forums saying that the ground plane must be connected to a vehicle electrical system ground point and that the antenna must have metal to metal contact with the ground plane, but I have also seen other HAM guys say that is not required so I am confused :-).
  3. Thanks for the information on antenna, I will go look into that. Yep I have the SW-33 as it seemed to be regarded as decent by some of the youtubers. what would be a decent one? I think most of my confusion is around what is a good ground plane. I have read everything from it must be connected a chassis ground point but can just be a bit of angle iron, or the antenna mount must be attached through a large metal surface, or as long as the antenna sits just above a large metal surface. I the case of my placement in the picture do I have any ground plane or just a bad one? Checked and the repeater channels are off by default on the radio, but if I change the power from hi to low on channel 22 the SWR drop to 1.34. I also tried the small magnetic mount antenna in that also came with the radio in the same location and ran the coax the same route and get a SWR or 1.12 across all channels.
  4. I am new to the whole GMRS radio thing and have been finding some conflicting information on the internet. My setup: Midland MXT275 with MXTA25 ghost antenna connected with provided coax cable. The antenna is mounted an antenna bracket that attached to a load bar on a aluminum truck bed cap. The bottom of the antenna sits about 2 inches above the roof of the bed cap. On channels 1 to 7 SWR of 1.46 and 2.1 on channels 16 to 22. So my questions are Will that aluminum roof make a good enough ground plane? If so does the antenna need to be mounted directly to it or is sitting an inch or 2 above it ok? Don't really want to drill holes in the roof. The mounting bracket is painted and I have had people tell me I need to remove the paint where the antenna attaches and also to run a grounding strap from the mount to the vehicle chassis ground, is this really the case? About the only thing everyone agreed on is that the MXA25 is not a great antenna, any recommendation for something to replace that with that is not too tall and will fit on the existing NMO mount?
