WRQX938
1 Follower
WRQX938's Achievements
  1. OK, thanks. I will do some testing over the weekend with the radios a distance apart and see how that goes.
  2. Ok, that is good to know. They were in fact within a foot or so of each other. I will try that test and see what results I get. Otherwise does the configuration in CHIRP look correct?
  3. I just received my GMRS license and working on setting up my 2 GMRS radios (Baofeng) with CHIRP. I am trying to add a couple local GMRS repeaters and not sure If I am setting them up correctly. If I transmit on either of my GMRS I hear the squelch tail back from the repeater, but I am not hearing what I am transmitting on my other radio. I am attaching a screen capture of my CHIRP settings as well. The closest repeater to me is the one listed as HRN550 and that is the one that I have been testing with. I set the tone mode to TSQL since the repeater is configured with both an input and output tone that match. One other note if I transmit with 1 radio on GMRS channel 15, I do hear it on the repeater channel of the other radio. According to MyGMRS the settings for the repeater are as follows: Frequency: 462.550 Mhz Output Tone: 136.5 Input Tone: 136.5 Repeater Type: Open System Am I doing something wrong with my configuration or am I not understanding correctly how it should work. If both radios are on the repeater channel and I transmit on 1 should I not hear it on the other as long as I can reach the repeater?
