WRUC860
WRUC860's Achievements
  1. Same !! I loved my GMRS Slim Jim so much I purchased one for my 2M/70CM as well. Great product and great value. Ask Joe to custom-tune it if you like. If you are primarily using repeaters, then you may want to stretch your sweep up a bit. SWR's on mine are on the floor.
  2. How do I expand the Tx and Rx to accommodate GMRS? I am legit on both. Does the software specific to the UV9PX allow this expansion? Thanks ahead
  3. Set CH22 as a "priority channel."
  4. That's what I figured. On my DD Explorer, I have the 1/4 wave whip and it seems to perform quite well. It actually doesn't extend as high as the OEM top-mount AM/FM/GPS antenna. I have just enough room to ensure 12"-12" GP on the top with the full-length sunroof. Even when standing outside the vehicle, the 1/4 wave outperforms my N 771G rubber duck.
  5. Question for the OP and others: Does the "Ghost" perform better than a Laird-Tram-Midland etc 1/4 wave NMO mount? Being only 6" tall, seems doable in your need. Just asking.
  6. Provided the antenna is properly tuned to the GMRS frequencies AND your cable/connector losses are low, you should see a marked increase in Rx and Tx over "some" 1/4 and 1/2 wavelength antennas. There is a lot of math and physics that go into any perceptible difference in distance and quality of comms. Probably the most important element to consider is "line of sight" based on your height ASL. Good luck
  7. Thanks for all the conversation. I decided to order a single-band Slim Jim and test the waters from there. I can always add the Tram 1173 and mount at a later time for one of my vehicles. Carry on and 73's Barry
  8. The Slim Jim I am currently looking at offers a SMA f connector that will resolve connector issues. The less "adapters" the better the performance I believe.
  9. Thank you BoxCar, I fully understand the height-factor but I'm thinking the trade-off of indoor vs outdoor would favor outside, on a metal patio table. Even though it would be a "table height," either would out-perform an indoor installation. Your thoughts ? The beauty of purchasing both is that I could use the Tram on the roof of my Explorer (except for entering my garage) and the Slim Jim while camping or traveling...indoors or outdoors. The dBi gain of the Tram should out-perform the "unity gain" of the 1/4 wave on the Explorer roof. Again, thoughts ?
  10. Thanks for the advice. I am intrigued by the Slim Jim and will probably get one anyway considering the portability. I guess I did not describe my other option well enough. I am specifically looking at the Tram 1173, a NGP 5/8 over 5/8 mobile or Browning BR 450, attached to a magnet NMO mount. My mental plan here is to attach it to a patio table (or higher) for better Rx/Tx. The radiating pattern of the 5/8 over 5/8 is a bit more horizontal than even the Slim Jim and "should" provide a bit more range for my situation. Thoughts ????
  11. Wouxun 805G. I have 1/4 on top of Explorer and get good results. The rubber-duck obviously doesn't work well in the house to reach simplex or repeater. I am thinking of either a Slim Jim hung outside the window OR a Tram 1173 5/8 over 5/8 just outside the window. My local repeater is about 5 miles from the house I would love feedback and suggestions from the hive on my best choice. Barry
  12. I can hit the Little Rock Metro repeater from the Lonoke exit nice and clear. It checks out around 30 miles west until I loose usable signal. Running an HT with 1/4 wave on roof. 462.650, 141.3 Barry WRUC860
