I was checking a couple of MURS radios today and was transmitting in my kitchen, the wall GFCI Plug started to buss when I transmitted and no longer works.
Anyone ever have that happen to them?
I think everyone that has been on GMRS.com after a month of use has found out it is worth $5.00 a month for a membership, I think just the knowledge you get from reading old post is worth it as well as the list of local repeater. And it would not hurt to send a couple buck to the repeater owners every once in a while.
If I am reading this right, HOA's will have no authority to deny an antenna.
https://www.arrl.org/files/file/HR9670/HR9670-Amateur-Radio-Emergency-Preparedness-Act.pdf
I think my first problem was buying equipment (got a good deal on them) before I knew what I needed or knew what I was doing. I thank everyone for the loads of information, I have learned more here then anywhere.
I am going to stick with the gmrs and study for the ham tests and then go from there. If the world ends before I get licences , I will still have the HF radios in the closet.
I have been looking for a place with more land in Indiana and then will set it up there.
My next project will be solar for my security cameras and radios.
Well now I am new to all this, other than the use on the fire dept. radios, I was unaware of the voltage coming from an antenna as well as any major radiation, I am wondering now if I should hire someone that knows what they are doing.
I purchased a dipole, which is 68.8 ft long, I had planned to mount it about 1 or 2ft above the roof ( I have an HOA) using poles and an insulator at each end. However my roof is only 52 ft long.
My question is what do I do with the extra 8 or so feet on each side? Can I just run it down the edge of the roof?
For the coax, do I have to run it straight down the middle of the roof or can I run it along the roof top with the wire?
I have an HF to listen to and want to have an antenna ready to transmit when I get my license or Lord forbid and emergency.
Thanks for everyone's help
It pretty flat but trees. I have a 25ft antenna, looking for about 5 miles. My base reaches the portables, but I would like the portables to reach each other with out the base relaying the messages. I looked at the Retevis rt97, If I read it right it will not do tones.
I have an HOA also, What I did was installed a TV antenna, they can not ban those or cloths lines. Something to do with natural things or something. I then put my gmrs on top of the tv antenna (on the pole) You see the tv antenna but have to be really looking to notice the GMRS antenna.
I hear you, I am new, I do not mind Paying to play, but donating and then waiting and hoping, nope not for me. I do like your idea, but I am wondering to if the owner then gets your name out there and no one talks with you then that would be bad also.
I don't know if I would do that, first you tick the owner off and will never get "approved" and second by putting in the correct tone, you essentially broke into his system.
