WRUT935
Everything posted by WRUT935
Getting into a repeater, but not getting a return
WRUT935 replied to Borage257's question in Technical Discussion
I know this is an old thread but of interest as I am experiencing similar issues with the OP. I do hear the reply’s from the other stations on the repeater but often with lots of static. They say I am coming in clear but they come in weak, with lots of static. I have raised my Ed fong GMRS antenna to my max (2 story house chimney stack plus a 10 foot pole). I have tried two radios ( Wouxun KG 1000G + and a Kenwood KT 8180). Yes certain days and time it is all clear both RX and TX. I would think that my TX will be more of an issue than my RX. I do understand my geo challenge with hills around me to the direction of the repeater. Moving to yagi may potentially help but will leave me directional unless I also invest on a rotator. 73s -
Base Station Versus Handheld with Aplifier
WRUT935 replied to pwindsor's question in Technical Discussion
I used the btech amp. It is rated at 40 amps but with the increased output of the Wouxun HT I was measuring over 45 watts at times. Be careful not to transmit on the FRS and low GMRS channels, else you are blasting them and not following regulations. If you don’t use the frs channels, you can just turn off the transmit on those just like mobile. -
I used a KG UV9G pro with a Btech 40 watt amp for months and it served me well. I use an Ed Fong antenna on the roof. I recently upgraded my base to the KG 1000 G+. I am now repurposing my amp on my new project, GMRS go box ? -
10 on high about 8 on mid power as shown on the PS meter.
@Steveshannon - Dr Fong's site advertises 5 dB for his GMRS antenna, does that translate to 7.15 dBi?
Has anyone compared this to the Ed Fong GMRS Jpole in PVC. Specifically, will this be an upgrade over the Ed Fong antenna?
Had mine for a month now. Love it. CHIRP Next works with it. I just redid my code plug from reset and the ability to copy and paste between files makes setting up the config a breeze.
Ya, I saw that, I dont like that they only offer it with SMA Female which means you have to add a converter for other radios like the Wouxuns, I would be nice to have it on BNC without the need for another adapter. With this length, using a BNC will make it easier to remove and or to swap with a shorter antenna. The 15 inch 771G is a bit long to walk around with but has given me a noticeable performance boost.
Copying from KG-XS20G or KG-UV9Pro CPS to the KG-1000G+ CPS
WRUT935 replied to WRUT935's question in Technical Discussion
The CPS from Wouxun downloaded from But Two Way. I can select a row, then copy and paste it on another row from within the CPS but not paste to another CPS. So copy from the KG-XS20G CPS to the KG-1000G CPS does not work. Unfortunately, each of the Wouxun models have a different CPS. -
WRUT935 posted a question in Technical Discussion
I have channels programed on my XS20G and UV-9PRO and would like to copy them, even line by line but not field by field to the CPS of the 1000G+. Is there a trick on doing that? Tried it an no bueno. I also tried opening the saved settings and that does not work, "incorrect file format". Or do I have to buy another program? -
I just for this 50W 50 ohm dummy load. XRDS-RF from Amazon. I directly connected it to my SureCom meter, no cables and no adapter needed. I keyed up and read both wattage and SWR, the SWR shows 1.7 which is higher than what I get through my outside antenna with 45 feet of cable! Is this just a bad dummy load or am I missing something. I expect 1.1. I measured the resistance using a digital ohm meter and it read 49 ohms. Why am I checking SWR? To use the dummy load to measure line loss of the cable. Professor Ed Fong told me it would be good reference to measure the SWR introduced by the cable and measure again with the antenna. This way, you can tell what is contributing to the overall value. I know there are a lot pricier dummy loads, is this brand/unit bad?
Welcome back to GMRS, just another thought, make sure no tones are pre set by Retivis that may filter your reception. 73s
Sad, poor reliability.
Update, got a replacement, working fine. So the issue is with the radio.
I have been using my BTECH U25 with my Wouxun KG-UV9G Pro (5+ watts) for a few weeks now. It is connected to an Ed Fong antenna on my roof with 45 feet of KMR400 (thick cable similar to LMR 400). 20A/30A peak PS. I have a Surecomm SWR/Power meter connected. SWR without the AMP (direct connected not bypassed) is less than 1.1, as low as 1.01. SImplex: GMRS 19 = 1.2 SWR Watts = 48W Repeater Channels: 1.3 SWR = 46 W Highest reading I got was 49W. I have a Wouxun KG-20G which I alternate with the BTech Amp setup using the same antenna. Since I can only TX at 20W, some repeaters could barely hear me. I am challenged with a quarry and a mountain range on my SW. The extra wattage does help and the BTech mic seems tx much louder, I am told by those who I have done test with switching radios.
No, the BNC will not/should not throw off SWR. I use 771 G on all my HRs and makes it easy to remove. Makes it easy to switch to my mag mount when in the car.
Just got the replacement mic from buytwoway. The new mic has the same issue as the first. I wrote the vendor back and hopefully will hear tomorrow. I hope I just got another bad mic and that the radio is not defective. those who own the kg-xs20g plus, have you tried to switch from spk1 to spk2 and is the mic speaker working properly?
I have the same model from buytwoway. I experienced it once but mine is connected to a PS, voltage on both the radio and a digital voltmeter shows 13.7 Volts and SWR is less than 1.2. I am having speaker 2 issues, the one on the mic. They already sent me a replacement mic and the problem persists, I just hear a little crackling sound out of spk 2. I hope Wouxun workmanship is doing down.
FYI - the speaker on the mic is broken, only weak crackling sound coming out when on speaker 2. Buytwoway radio customer service responded quickly and they are sending me another mic. Great customer service.
When I switched the menu from speaker 1 to 2 so that the audio comes out of the handset speaker, I just get a very low scratchy sound. I adjusted the volume on the handset as well as the unit. Still waiting for a response from buytwoway on this. Have you guys have this issue?
LOL- did not even realize that. I dont even have that model, I have two Wouxun KGs. Thanks you FCC ?
Thanks to Randy's discount code, I got my unit a few days ago. An early xmas gift from my wife. I have a Wouxun KG-UV9-Pro from BSR. Both radios a very good. The 20+ watts makes a big difference for me due to the hills and Mt. Diablo near me. I was able to connect to the repeater in Sunol and was able to converse with clarity. I paired it with a pyramid 6 amp PS. I have an Ed Fong antenna on my roof/side of the house (HOA) with a 25 foot KMR 400 (amazon) cable. My SureComm digital meter shows upto 22 Watts out with SWR of 1.18. So far no issues. There was one weird anomaly this afternoon that the tones for one of the repeaters got set to off, hence it can't talk and hear on that repeater. Watch Randy's videos on this model to get to additional info, he has one when it first came out and a follow up when it went "plus". The free Wouxun software makes it easy to change setting but it does NOT have the ability to import/export. My UV9-Pro has tons of channels and I can't port them over, not even copy and paste using the Wouxun software. The RT systems software (around $25) does not show one for the xs20G. The Wouxun Commander for the XS20G does not recognize the file output from the UV9-pro. WRUT935/Benjo
Radioddity not keeping High Power Settings
WRUT935 replied to rroscher's question in Technical Discussion
Raddiodity has excellent support, they may be able to tell you what to do and or send you a firmware if needed. They sent me a firmware to fix the FM issue. -
Ensure that the driver is properly communicating with the comm port that the cable is plugged in. The device manager will show that. If you can’t “read” the radio from the computer, try anothe usb port. Most of the time it is a driver issue.
