WRQC345
WRQC345's Achievements
  1. As of 2022-12-09: Files available from their website: GM-30_Firmware & Software_V1.05 GM-30_Firmware 20210403 & Software_V2.06 GM-30_Firmware 20210615 & Software_V2.06 -----reply email from Radioddity Hi Dennis, 6.03.009 is the latest firmware from 11.17.2021 6.03.006 was the previous from 6.15.2021 6.03.003 (IIRC) was in the 4.03.2021 release 6.03.001 was in the V1.05 download from 3.18.2021 6.03.009 and 6.03.006 are the same, except 6.03.009 was provided for GM-30 radios that had a chip change due to supply shortages and the FM broadcast radio did not work. That is the only difference I have found. If you have v6.03.009 and the FM Radio can pick up local stations, that is as new as is available. Cheers, David ________ Radioddity Support Team
  2. It would be helpful if Radioddity would post firmware files with FILENAMES that reflect the FIRMWARE VERSION as well. I couldn't find it inside the ZIP files either. It seems the only option is to just flash the firmware and hope it's an update? Per this post, it's potentially a downgrade though. I've emailed them and will post any reply here since this post is showing up in Google searches.
  3. Your post is still useful. I read the original and re-read it several times trying to find the difference between the two identical firmware versions. When I saw your post, I knew I wasn't crazy.
