Hello! I'm new to mobile radios so I want to make sure I'm not doing something wrong before I send my radio in.
I've got four TIDRadio H3s, two GMRS units and two ham units that were unlocked and changed to GMRS mode. I've been trying to hit a local repeater unsuccessfully so I picked up a Surecom SW33 to make sure my radios/antennas are actually working correctly. Three of the four are showing a VSWR around 1.4 and an output wattage around 5W with the same antenna so I think I'm just too far out from the repeater to hit it.
The problem is the fourth radio (one of the ham units) doesn't show anything on the SW33 when transmitting. Other radios can hear it transmit short range - I've tested it on simplex channels across the house and through some walls but nothing long distance - but the SW33 is acting like it's not doing anything.
(Edit: Should note I also tried it with the 50 ohm dummy load that came with the meter and still got no output reading.)
Are there other things I can check or change in my test setup or was this radio DOA and needs to be replaced?
(Side question: regarding forum etiquette, should I have piggybacked off GrouserPad's similar thread for this or was starting a new thread appropriate?)
hxpx
Edited by hxpxAdded test note
Top Posters For This Question
16
14
9
8
Popular Days
Jun 23
19
May 19
8
May 9
6
Jul 3
5
hxpx 16 posts
SteveShannon 14 posts
LeoG 9 posts
GrouserPad 8 posts
Popular Days
Jun 23 2025
May 19 2025
May 9 2025
Jul 3 2025
Popular Posts
SteveShannon
Based on GrouserPad’s experience that’s not uncommon, unfortunately. There’s no reason to doubt your (or his) experience. TD H3s apparently arrive dead or die shortly after. Don’t waste time double
hxpx
Just as a quick update: I contacted TIDRadio about it and they sent me a new unit. Confirmed the new one outputs 5W with a dummy load and a 771 antenna. If nothing else, their customer support was pre
hxpx
@SteveShannon Ah, beans. That's what I figured but I wanted to make sure I wasn't missing something simple. Thanks for your help! @Socalgmrs Interesting, I'll have to read up on that. What's not
Posted Images
53 answers to this question
