WRHS218 Posted June 18 Report Posted June 18 I was out and about the other morning and while waiting on someone I turned on my KG-Q10H. The last time I had used it I had it set to TDR monitoring the local Sheriff’s frequency and a local 2m repeater. When I turned the radio on all was as I had left it except the speaker icon on both areas had a line through it. I was not receiving any signal in either area. No signal strength bar and no green light indicating the radio was receiving. I normally have my KG-935G in the car with me so I turned it on and was receiving traffic on both of those same frequencies. I went through the menu settings and nothing was muted. I was able to go through both menus and could select any saved channel and still no receive. When I tried to transmit to the 2m repeater nothing happened, no red LED no signal bar. I moved to a simplex frequency and tried to transmit with the same result. While sitting there I went ahead and did a factory reset through the menu option 48 and when the radio restarted the line though the speaker icon was gone. I was able to punch in the SO frequency and the 2m repeater frequency and received traffic on both. I was able to transmit to the repeater and on simplex. When I got home I reprogrammed the Q10H via the Wouxun software and all is good. I have checked it daily since that happened and the glitch has not occurred again. Just thought I would share the experience in case this happens to anyone else. The KGQ10H replaced an 18 year old Yaesu VX-6R that up and died on me a while back. The Q10H is a great radio and this is the first issue I have had with it. In the 18 years I had and used the Yaesu I had turned it on several times and found that the memory was wiped, so weird things happen. Quote
LeoG Posted June 18 Report Posted June 18 The new fangled radios are all computers now. And just as any computer might need the occasional reboot so do radios. Having to do the reset is just a step farther. I had to do it on one of my Wouxun radios that was acting weird. Fixed it up and I just hooked it up to the computer and reflashed my channels back into it. 5 minutes and done. But this would be a serious problem if it was an emergency. Good old fashion radio guts with no computer can have an advantage sometimes. Same goes with automobiles. WRUU653, WRYZ926 and WRHS218 3 Quote
WRUU653 Posted June 18 Report Posted June 18 My first thought is if the radio received a remote stun or kill. Page 108, 109 in the manual. Though random glitch is probably more likely. WRHS218 1 Quote
WRHS218 Posted June 18 Author Report Posted June 18 1 hour ago, WRUU653 said: My first thought is if the radio received a remote stun or kill. Page 108, 109 in the manual. Though random glitch is probably more likely. I thought about that too, but thankfully a reset fixed it. I don't think a reset will help with kill or stun. WRUU653 1 Quote
WRYZ926 Posted June 19 Report Posted June 19 I have not had any problems with my Q10H yet. But I have had other brands of radios act up. though usually just reloading stuff fixed them. I've had Icom and Yaesu radios have glitches too. WRHS218 1 Quote
