WSCU408 Posted July 2 Report Posted July 2 (edited) Copied to Technical Forum (sorry for the misplace). I have been using my radios in simplex mode for about a year now with no issues. I now have reason to use a local repeater that I have been granted access to. To verify it is working I am using two radios ( a Wouxun KGS-88G and a Baofeng UV-9G). These radios are used to talk to each other in simplex mode whenever we are out and about fishing or hiking. I have tried using channel mode (Repeater 16) on both and entering the given DCS . I have also tried Freq mode by entering 462.575 as wll as the DCS code for both Tx and Rx. The 88G seems to transmit as I see the frequency change to 467.575 when I PTT the UV9G will indicate it has an Rx signal when monitoring 467.575 via frequency mode, but I hear nothing (squelched out?). What am I doing wrong? Edited July 2 by WSCU408 Copied to Technical Forum Quote
OffRoaderX Posted July 2 Report Posted July 2 I asked this question twice on your other post and still have not received a response, so i'll ask more slowly this time: How ... farrrr.. aparttttt.. areeee.. theee... twooooo radiosssss ..whennnnn youuu are testinggggg themmm? Quote
SteveShannon Posted July 2 Report Posted July 2 1 hour ago, WSCU408 said: What am I doing wrong? Try leaving DCS empty on the receive side and make sure you keep the transmitting radio some distance away from the receiving radio. Quote
