WSEZ969 Posted July 6 Report Posted July 6 Can anyone tell me what we would use this programming screen for inside CHIRP ? Can you give an example and purpose Quote
SteveShannon Posted July 6 Report Posted July 6 3 minutes ago, WSEZ969 said: Can anyone tell me what we would use this programming screen for inside CHIRP ? Can you give an example and purpose Some radios allow “selective calling” where you can send a code to one specific radio and it will listen while other radios ignore you. WRTC928 1 Quote
WSEZ969 Posted July 6 Author Report Posted July 6 I appreciate your reply. Thank you SteveShannon 1 Quote
WRTC928 Posted July 7 Report Posted July 7 23 hours ago, SteveShannon said: Some radios allow “selective calling” where you can send a code to one specific radio and it will listen while other radios ignore you. I'm aware of the use of DTMF codes to send instructions to a repeater or other device. Are you saying they can be used HT-to-HT or mobile-to-mobile to determine who receives your signal? Yes, I know there's no such thing as true security with any unencrypted radio signal, but I can envision situations where it would help reduce confusion. Quote
OffRoaderX Posted July 7 Report Posted July 7 34 minutes ago, WRTC928 said: Are you saying they can be used HT-to-HT or mobile-to-mobile to determine who receives your signal? Yes, I know there's no such thing as true security with any unencrypted radio signal, but I can envision situations where it would help reduce confusion. KINDA .. IF all the radios are compatible with the feature and IF all the radios are correctly configured, you can use the Group Call (also has other names depending on the manufacture) feature to talk to only certain radios in your group. HOWEVER - Radios not configured to do this and radios not compatible will ALL HEAR everything you say — Basically it is a fancy squelch or call-tone limiting only what the radios configured for your groups can hear (they can only hear their group), but all other radios can still hear everything. WRTC928 and SteveShannon 2 Quote
WRTC928 Posted July 7 Report Posted July 7 23 minutes ago, OffRoaderX said: Radios not configured to do this and radios not compatible will ALL HEAR everything you say I was assuming they could. That's what I mean that there's no security with a radio signal. 23 minutes ago, OffRoaderX said: Basically it is a fancy squelch or call-tone limiting only what the radios configured for your groups can hear (they can only hear their group), but all other radios can still hear everything. I can see where that might prove useful if you're working with a large group of people where some things need to be heard by everyone, but some things only need to go to a subgroup. I have no use for it now, but there were times in the past when I would have found it helpful. Interesting to know. SteveShannon 1 Quote
