WSEA459 Posted 8 hours ago Report Posted 8 hours ago How do I download repeater lists for different states? I will be traveling soon and want to have the list in the car mostly for the tones. Quote
WRUE951 Posted 3 hours ago Report Posted 3 hours ago 4 hours ago, WSEA459 said: How do I download repeater lists for different states? I will be traveling soon and want to have the list in the car mostly for the tones. up to a few weeks ago you could use Excel to extract data from the site using simple Excel tools but the owner has since locked down his site stopping these Excel tools. However there are still other tools available, some open source, that will continue to work and allow the extraction process. You will need to learn how to use compliers with these tools but they work perfect.. Google HTML data capture and look for open source tools. Lots of youtube videos out there too. Note that it will also me handy if you know how to write macros as this will speed up process of sorting. Good Luck! Quote
SteveShannon Posted 3 hours ago Report Posted 3 hours ago 5 hours ago, WSEA459 said: How do I download repeater lists for different states? I will be traveling soon and want to have the list in the car mostly for the tones. Premium members of this site can generate reports in CSV format using whatever search combination they want. As far as I know that’s only available to premium members and the only way to export data. Quote
WRUE951 Posted 2 hours ago Report Posted 2 hours ago 9 minutes ago, SteveShannon said: Premium members of this site can generate reports in CSV format using whatever search combination they want. As far as I know that’s only available to premium members and the only way to export data. very limited. And no, not the only way.. as i stated above Quote
SteveShannon Posted 1 hour ago Report Posted 1 hour ago 1 hour ago, WRUE951 said: very limited. And no, not the only way.. as i stated above You seem troubled. You previously described something that by your own admission “used to work” or requires using a compiler. It’s far easier to just run a report to generate the CSV file in a method officially provided by the owner. Premium membership is a small price for such convenience. Quote
WRUE951 Posted 21 minutes ago Report Posted 21 minutes ago 1 hour ago, SteveShannon said: You seem troubled. You previously described something that by your own admission “used to work” or requires using a compiler. It’s far easier to just run a report to generate the CSV file in a method officially provided by the owner. Premium membership is a small price for such convenience. With all due respect, go back and read my last comment here, it was very clear. And as stated in prior comment, pulling data still works. It’s just not as easy using common software such as ad Excel. Quote
