Wouxun KG-1000G faceplate screws
Wouxun KG-1000G question:
Does anyone know of a source for the 2mm self tapping screws used install the front panel onto the inclined switchboard channel or the flat switchboard channel.  The flat panel uses 11 mm long screws and the inclined panel uses 16 mm long screws.
3 answers to this question
Just get the same size screws from the bins at Ace, Home Depot, or Lowe’s. Because the old screws already tapped the threads you no longer need self-tappers.
I've actually 3D printed some small screws for circuit boards.  They work fine as long as you don't overtighten..
