rfjunkie Posted 19 hours ago Report Posted 19 hours ago On 8/4/2025 at 1:45 PM, TNFrank said: Here's a list of what I've gotten so far. I'm still having trouble with Repeater Off Sets but I think I've got it right. The listed frequency is the RX and you use the Off Set for your TX Frequency, correct? HAM Channels. 28.93 kB · 6 downloads Recent Technician here. From my travels on the net so far, it seems you may want to also add the following for simplex communication in 70cm: Discovered via https://www.azfreqcoord.org/bp/bp.htm (PDFs of the bands are on the left menu). 446.0000 Simplex (National Calling, already included in the list) 440.9250 Narrow Band Simplex 441.0250 Simplex 446.0250 Simplex 446.0500 Simplex 446.5000 Simplex Finding these band plans is really helping me program up my HTs. How goofy will I look hanging out on top of a mountain, surrounded by 6 HTs (*one decent one for Tx and 5 or so more cheap ones for dual watch coverage of multiple channels?) Idk but I kind of want to find out.. . There are 2m and 1.25m VHF band plans with similar designated simplex frequencies that can be used, plus repeater listings linked to in the upper left of the menu that's worth a look. My guess is that repeaterbook status info is more up-to-date than static PDFs, but they also sort by location and have maps pinned for some bands in the lists. Lscott 1 Quote
TNFrank Posted 19 hours ago Author Report Posted 19 hours ago I've added a bunch more 70cm Repeaters since I picked up a 9db Yagi for that band. The antenna also has an SWR of 1.01:1 for 70cm and 1.03:1 for GMRS so it should be fun to play with. SteveShannon, Lscott and rfjunkie 3 Quote
radioruck Posted 4 hours ago Report Posted 4 hours ago 14 hours ago, TNFrank said: I've added a bunch more 70cm Repeaters since I picked up a 9db Yagi for that band. The antenna also has an SWR of 1.01:1 for 70cm and 1.03:1 for GMRS so it should be fun to play with. Have you noticed a major improvement in reach/distance with the yagi? Quote
TNFrank Posted 4 hours ago Author Report Posted 4 hours ago 27 minutes ago, radioruck said: Have you noticed a major improvement in reach/distance with the yagi? I still need to get out and give it a try on some of the further repeaters. I really want to give it a try on simplex to see if I can TX/RX further. radioruck 1 Quote
