I have a few different antennas from small stubbies(Diamond SRH805s) to a 3.14" longer stubby(Abbree AR-806+,my go to for my work radio) to the mid-length(8")whips and the longer 15.3" Arbbree AR-771. I'd guess that the 771's would give me the best range on par with other 771's like the Nagoya, et al. Question is are there any other antennas that might give me a bit more gain and still be portable enough or is something like a 771 type antenna about as good as it gets?
I'll not only be using it on GMRS and MURS but also on 2M, 1.25M and 70cm now that I have my Technician License. Thanks.
TNFrank
Top Posters For This Question
12
6
6
6
Popular Days
Aug 10
23
Aug 12
9
Aug 11
8
Aug 14
7
TNFrank 12 posts
Lscott 6 posts
SteveShannon 6 posts
WRUU653 6 posts
Popular Days
Aug 10 2025
Aug 12 2025
Aug 11 2025
Aug 14 2025
Popular Posts
WRUE951
a long time ago i shelled out some good money ($45) for a Comet (i don't remember the model) HT dual band antenna. I never was able to ascertain the difference between that and the standard stock ant
WRUU653
Each frequency is its own tuning so if you are looking for the best you can do it will depend on what you are doing. I generally use the stock antenna on my HT radios. If you are trying for more, som
hxpx
I use a Signal Stick which is only 2m/70cm but it glows in the dark (though they say it will "probably work" on GMRS/MURS). I bought it because the Signal Stick guys run hamstudy.org and I wanted to s
Posted Images
55 answers to this question
