WRUE951 Posted 12 hours ago Author Report Posted 12 hours ago 6 hours ago, TrikeRadio said: I just wonder how well that cheap magmount antenna sticks to the airplane. my first guess, they're using HT's . And my second guess, based on where i think they were flying, 25 miles from my location.. amaff 1 Quote
amaff Posted 12 hours ago Report Posted 12 hours ago 1. I don't understand why mag mounts are even being discussed. Pretty sure that was brought up as a joke lol Yeah, they're not a good fit for aircraft for obvious reasons. There's not usually a lot of steel in an airplane, outside of the engine mount. 2. There are air-to-air dedicated frequencies on the air-band. However: Not all air band radios, especially in older planes, allow dual watch for monitoring the Unicom or Controller frquency for your airspace, and also allow you to talk to your buddy in the plane next to you. And air band radios are expansive as hell. If you need an inexpensive solution to be able to talk to your buddy, adding a GMRS or FRS radio seems like a good option vs spending $$$ for another air-band radio. Hell, a lot of older and light sport aircraft aren't even required to have a radio installed, depending on the air space they fly in. If you fall into that category, are you going to spend $$$ for a 'real' air band radio for your plane that doesn't even have an electrical system? Or throw your GMRS handheld and a headset in your pack? Quote
WRUE951 Posted 12 hours ago Author Report Posted 12 hours ago 9 hours ago, OffRoaderX said: But that's not what he said he has. I know,, Just saying, who many of us have a 5RM and refer to them as a UV5.. I do cause i'm a lazy 'ole fart Quote
TrikeRadio Posted 9 hours ago Report Posted 9 hours ago 2 hours ago, amaff said: 1. I don't understand why mag mounts are even being discussed. Pretty sure that was brought up as a joke lol Yeah, they're not a good fit for aircraft for obvious reasons. There's not usually a lot of steel in an airplane, outside of the engine mount. Yeah, it was just a joke. sorry. I was just visualizing a mag mount flying off a plane... must have been late last night when I was posting. amaff and WRUU653 2 Quote
WRUU653 Posted 9 hours ago Report Posted 9 hours ago 9 minutes ago, TrikeRadio said: Yeah, it was just a joke. sorry. I was just visualizing a mag mount flying off a plane... must have been late last night when I was posting. That's why the majority of pilots will just put a mag mount on a cookie sheet in the window... amaff 1 Quote
WRYZ926 Posted 8 hours ago Report Posted 8 hours ago 46 minutes ago, WRUU653 said: That's why the majority of pilots will just put a mag mount on a cookie sheet in the window... A round pizza pan would be more aerodynamic Quote
WSGL775 Posted 4 hours ago Report Posted 4 hours ago 17 hours ago, OffRoaderX said: Go ahead and tune your UV-5R to 122.750 and tell us how that works out. So I tuned it to that frequency. Haven't heard anything, nothing, bupkis! That's how it worked out! Quote
WSGL775 Posted 4 hours ago Report Posted 4 hours ago 9 hours ago, nokones said: You will not hear the helicopters. 122.750 MHz is designated for fixed wing aircraft, that means airplanes that have stationary wing(s). If a helicopter (rotary wing) meaning having a wing that rotates and spins around needs to communicate with an airplane then you may hear a helicopter. Aeronautical freqs are amplitude modulation freqs., so I doubt that your Barfwanger Pandaland radio will emit Amplitude Modulation since they are frequency modulation radio devices. Okay. Didn't think it would, but just a shot in the dark. However, I believe if I fire up my PRC 77, I'll get traffic..... Quote
