Being new to GMRS, I am constantly finding myself confused. This time I think something is wrong, but I have no clue what it is. I have the Wouxun KG100G radio base with a Comet antenna thirty two feet into the air. In my vehicle, I am temporarily using the five watt Wouxun KG935G hooked to a ghost antenna on the roof. Both radios are correctly set with the repeater tones. Both of the radios will connect with the repeater mentioned above, and on each radio I can talk to others via the repeater. However, the mobile and the base radio will not talk to each other, even though both radios hit the repeater. As a side note, Three days ago I was in the mobile directly dead center of the repeater coverage area, I could hear the repeater and others talking, but I could not communicate with the base radio.
The exact same scenario, only using a repeater that doesn't come closer in range to the base than twenty miles, I can switch both the base and the mobile to this repeater, and they will talk to each other. Since the first scenario has a repeater that ranges closer to the base, I feel that the closer repeaters abilities should allow both the base and mobile to talk to each other. I am absolutely certain that the repeater tones are set correctly. I can talk to others over both radios via the repeater, just not mobile to base in the first scenario. Any suggestion would be greatly appreciated.
WSIM522
4 answers to this question
