WSFN703 Posted December 20, 2025 Posted December 20, 2025 I ordered a couple of pairs of UV-5Gs for family. When I got them out of the box a few minutes ago to program them I noticed they were sporting female sma antenna connectors on the radio. The older ones that I have are the male sma connectors. Anybody know why they changed or why? I don't guess it really makes a difference. Quote
SteveShannon Posted December 20, 2025 Posted December 20, 2025 8 minutes ago, WSFN703 said: I ordered a couple of pairs of UV-5Gs for family. When I got them out of the box a few minutes ago to program them I noticed they were sporting female sma antenna connectors on the radio. The older ones that I have are the male sma connectors. Anybody know why they changed or why? I don't guess it really makes a difference. Over the years I’ve heard many people concerned about using an SMA with the small (maybe fragile) center pin on the radio. The concern is that the center pin could get damaged. If the center pin is on the antenna, the antenna could easily be replaced. No so if the pin is damaged on the radio. Almost all of my more expensive radios have the pin on the antenna side rather than the radio. All of my less expensive ones have the pin on the radio. WSFN703 and WRUE951 2 Quote
WSFN703 Posted December 20, 2025 Author Posted December 20, 2025 16 hours ago, SteveShannon said: Over the years I’ve heard many people concerned about using an SMA with the small (maybe fragile) center pin on the radio. The concern is that the center pin could get damaged. If the center pin is on the antenna, the antenna could easily be replaced. No so if the pin is damaged on the radio. Almost all of my more expensive radios have the pin on the antenna side rather than the radio. All of my less expensive ones have the pin on the radio. That makes sense. My Yaesu VX-7R has a female connector. SteveShannon 1 Quote
SteveShannon Posted December 20, 2025 Posted December 20, 2025 3 minutes ago, WSFN703 said: That makes sense. My Yaesu UV-7R has a female connector. Right; my VX6, VX7, and FT5DR all have the female center on the radio (there are actually four different permutations of SMA). My Yaesu FT65 and FT4, my Alinco DJ-MD5, Wouxun 805, TYT MD-UV380, and a couple Baofeng UV5R variants all have the male pin on the radio. I’ve added a BNC adapter to a couple of the radio. That allows me to easily swap antennas between them without having to screw and unscrew the antenna. WSFN703 1 Quote
LeoG Posted December 20, 2025 Posted December 20, 2025 Just looked at my TD-H3 and the pin is on the radio. Looks pretty sturdy but I suppose it could break. And your thought about it being on the antenna makes sense. SteveShannon 1 Quote
