Setting up repeater (total newbie call sign WSGA222)
Any guidance appreciated.
Repeater I want to use: https://mygmrs.com/repeater/11089  Info: Tx Hill Country GMRS WGT-725
My radio: Baofeng UV-5G (but lists as RadioOddity in CHIRP)
Open System
Frequency: 462.725 MHz
Input Tone: 331 DPL
Output Tone: 331 DPL
I don't see any offset listed.
I have included my chirp img if that helps.
Looking to understand a) how to setup properly.
2 answers to this question
  • 1
Open System
Input Tone: 331 DPL
The offset is automatically applied when you use a repeater channel. It looks like you already have the correct DCS code set for repeater channel 30 so just save it, write it to the radio, and try it.
  • 1
It looks like your offset is gone.  Like Steve said, it should be automatically applied.  All offsets are the same on the repeater channels.  Just make sure there's a + for duplex and 5 for the offset, like the others.  You should be golden then.
