hi all wqzr743 here . i am building a repeater for gmrs. it is based on the motorola rick system  i have motorola gm300 10 watt radios in it now but need more range. im looking at m1225 radios.will they work in a rick setup? ive got m208s but i cant get them to work with the rick controler. the rss software wont let me program in repeater mode. any ideas are greatly appreciated, thanks wqzr743
has any one used the id o matic controlers?
radio dan has them for about 80.00
Yes. IMHO, the functionality is minimal. Some people are fans, however, I was not impressed. There was a thread on this about a year ago, you could try searching for it.
for the OP - I believe that an M208 can be programmed using the generic Radius M100 CPS.  I believe "RADMBL" is the keyword to search on & find the program at HamFiles.
The GR300 was a nice & simple design, but we called them "hot boxes" due to the heat issues that killed high power applications. Keep it as a 10 watt & under repeater with clean, cool air flowing, and they worked well.  I'd be concerned about trying to run it as a 40 watt repeater with anything more than a 5 or 10% duty cycle.
