Hypothetical situation: A company that provides maintenance services to two large shopping malls approximately 25 miles apart has a radio system that uses 4 watt portables and two suitcase repeaters - one in each mall so the portables can all be heard in the separate malls without simplex drop out. The portables and suitcase repeaters also have REVERSE programmed as a "channel 2" so the two mall location supervisors can speak to each other directly by having the suitcase repeaters in reverse activate a conventional repeater centrally located between the two malls.
Since this may not be allowed on GMRS under Section 95.29b, I was wondering if anyone has used this setup personally in a non-GMRS venue and if so, was it effective to expand the two local systems into one communications network?
PastorGary
Any thoughts ? - Thank You.
20 answers to this question
