Eagle-1 Repeater
Guest spd641
Hello everyone just wanted to let everyone know my repeater is back on the air...finally got a new frequency and DPL to keep the riff raff down this time.
William, thanks for the update and info that you also provided in P.M.
I'll attempt to access it on November 01 mid-morning starting at about mile marker 300 on I-65.  If I can't get to it because of that high terrain just to the east of I-65 - I'll try to contact you simplex CSQ on the same output frrequency as your repeater, so we can do that equipment exchange at the fuel stop at the exit that you mentioned.
If you change anything between now and October 30, please let me know so I can reprogram the portable accordingly.  Thanks.
Guest spd641
PG,
I was out with my hand held yesterday and actually accessed the repeater from the 284 area so hopefully you will not have a problem,it seem this set up is working better than any other one I have had in the past.BTW I got you email and that will be good on the meeting and I will set up the 600 simplex CSQ and you remind me when you will be in the area...Wiliam
Good to hear your back on the air JR !!! I'm still gonna try to hilltop your repeater one day. I'm gonna need your new pl tone.
                                     Jim-WQNB686- KG4TEP
Just a reminder for members here - Spybots from Search Engine Companies are camped out here in the forum.  Any 'sensitive' information such as PL/DPL codes and frequencies for 'private' or 'permission only' systems should be done in Private Messaging Only.
Thank you.
Pastor Gary -
Forum Moderator
