Information
WRFU
Configuring your Router
In order for your node to accept incoming link connections, You will need to forward a port in your router so that incoming connections can
be passed to your node on your network. If you connect to your router's administration page you will find a section called port forwarding
or virtual servers. Here, you can forward UDP connection on port 4569 to the same port 4569 on the Pi's IP address Consult your router's
manual for how to set this up. Failure to configure this properly will cause only outgoing connections to work and potentially other issues.
TYPE: UDP
I check it out in my setting list was NO UDP..................
FTP
HTTP
ICUII
IP PHONE
NETMEETING/H.323
NEWS
QUAKE II & III
REAL AUDIO
TELNET
VPN_PPTP
2 answers to this question
... check it out in my setting list was NO UDP..................
FTP
HTTP
ICUII
IP PHONE
NETMEETING/H.323
NEWS
QUAKE II & III
REAL AUDIO
TELNET
VPN_PPTP
The protocol list you are looking at is for higher level, application, protocols. You want to look below that, at the transport protocol. That will either be TCP, UDP, or both. You will not see that choice until you select the higher level protocol. If you do not see a higher level protocol for your particular application, you can usually just enter the IP port number .
TYPE: UDP
FTP
HTTP
ICUII
IP PHONE
NETMEETING/H.323
NEWS
QUAKE II & III
REAL AUDIO
TELNET
VPN_PPTP
You want to go to "Advanced>Port Forwarding" You will have to chose the IP address the Pi is using, then select port 1 as 4569 using UDP, then port 2 using TCP on port xxx (Custom port number you want to set for the pi, this allows you and you alone to remote log in and edit files on the pi)
