KG805G - Disable Auto Keylock?
Bombahook1
Ok this is a stupid question, I'll own that right up front.
I enabled the automatic keylock (menu item #11) and I have not been able to disable it. Yes I read the instructions and it says to deactivate it to press MENU and the UP/DOWN buttons to get back into the menu, but that does not seem to be working on my radio.
I'm sure it's somthing simple that I'm missing, but for the life of me I can't seem to figure out how to turn it off. Anyone know the trick?
B
Link to comment
Share on other sites
3 answers to this question
After you set it to Off, make sure to press Menu again. Pressing Menu is what saves the current setting. Exit cancels the operation.
Sent from my iPad using Tapatalk
Thanks, I finally did figure out that you need to push and hold the exit button for 3 or 4 seconds to unlock it. It's not in the instruction sheet that I can find or it's written somewhere else in the sheet.
B
Link to comment
