wraw892 Posted November 20, 2020 Report Share Posted November 20, 2020 I am looking to download a copy of the distro you guys have on this group.I have a simplex node I could use in the San Diego Area. Also an Icom tkr-820 repeater.Not sure if you guys link up similar to that group gmrslinked network.Any info on this? WRAW892W3DAWYN1OB Quote Link to comment Share on other sites More sharing options...
0 WRAK968 Posted November 20, 2020 Report Share Posted November 20, 2020 There is no public download (That I know of) at this time. This is to avoid confusion with the ham radio side of Asterisk. Ontop of this, you will also need a username/password for the server, and I believe the linked network is limited to repeaters only (to avoid unlicensed FRS users from accessing repeaters through the 462 frequency)If you have the equipment already, you can contact Rich@MyGMRS.com and he can get you set up with the image and username/password. If you do not have the equipment, you can purchase it from https://shop.mygmrs.com/products/repeater-linking-bundle?variant=32248678744099 and choose an interface that will work for your radio. wraw892 1 Quote Link to comment Share on other sites More sharing options...
0 wraw892 Posted November 20, 2020 Author Report Share Posted November 20, 2020 Understood, It should not be different than the ham version. Slight differences I can think of is server address and username and password. Pretty sure that I can run a single node unless other wise not desired by the admins.As for the equipment need it aint much. I have the repeater duplexer and single board computer. Thanks for the InfoWraw892 Quote Link to comment Share on other sites More sharing options...
0 WRAK968 Posted November 20, 2020 Report Share Posted November 20, 2020 Understood, It should not be different than the ham version. Slight differences I can think of is server address and username and password. Pretty sure that I can run a single node unless other wise not desired by the admins.As for the equipment need it aint much. I have the repeater duplexer and single board computer. Thanks for the InfoWraw892Those are the differences to my knowledge. As I said, contact Rich and he will send you the file you need as well as a node number and password. If you have a pi and a way to wire it to the repeater then you should be all set. Quote Link to comment Share on other sites More sharing options...
wraw892
Any info on this?
WRAW892
W3DAW
YN1OB
3 answers to this question
