Kenwood TK-3173 Set Up
TDM827
I am researching commercial radios vs. the standard CCR offerings. After going deep down the rabbit hole I am leaning toward the Kenwood TK-3173 handheld, seems like a good quality radio others here use.
Searching through the forums I think I have a decent handle on what it takes to set up the TK-3173. So far it seems that in addition to the radio also needed is the programming softward ( Kenwood KPG-101D) and a good quality programing cable (from bluemax49er). If I am missing something I would appreciate if someone with this radio could let me know.
I also could not find any information about CTCSS and DCS codes in the online manual. Again, if anyone with experience with the TK-3173 could confirm that somewhere in the programming software there is the ability to set CTCSS and DCS codes for repeater use it would be appreciated.
Thanks
6 answers to this question
I have 3173 and 3170. For the purpose of GMRS these two are identical, and both are programmed with KPG-101D. There is indeed an option to set CTCSS or DCS separatley for receive and transmit, so called "split tones". On the Zone/Channel screen these columns are called QT/DQT Dec (receiving tone) and QT/DQT Enc (transmitting tone). You can set tones here. Another option is to use OST feature (operator selected tone) where you can program 40 tone combinations, and program a button on the radio to invoke the OST menu. This option is in Menu -> Edit -> Optional Features -> Conventional.
Thanks
You could also look at a somewhat older Kenwood radio model. I have used the TK-370G-1. You can find these radios with a full numeric keypad fairly often. Following the instructions in the service manual, removing a diode I believe, and selecting the self programming option in the software the radio can be field programmed through the front panel.
http://www.dannel.co.za/vertel/TK-270G-370G_5-Tone.pdf
Thank you axorlov and Lscott.
I remain very impressed with commercial Kenwood and Moto handhelds and was glad to hear they can be repurposed for private use.
Got a TK-3173, software and programming cable on the way. Still researching a12v battery eliminator pack, SMA external antenna and rapid vehicle charging kit.
