jk06 Posted March 1, 2021 Report Posted March 1, 2021 Hi,Do I need to add CTCS tones in order to communicate with the GMRS v1 hard loaded Channels? Thanks Quote
0 mbrun Posted March 1, 2021 Report Posted March 1, 2021 Codes are not needed when communicating with radios that are not set to use codes. Most radios are not set to use codes out of the box, it is therefore the user that decides if and when they are used. If you attempting to use a repeater, almost every repeater requires use of codes. In that case, yes you would program them into the radio and need to obtain them from the repeater owner. Hope that helps. MichaelWRHS965KE8PLM Quote
0 jk06 Posted March 1, 2021 Author Report Posted March 1, 2021 On 3/1/2021 at 2:24 AM, mbrun said: Thank you! Codes are not needed when communicating with radios that are not set to use codes. Most radios are not set to use codes out of the box, it is therefore the user that decides if and when they are used. If you attempting to use a repeater, almost every repeater requires use of codes. In that case, yes you would program them into the radio and need to obtain them from the repeater owner. Hope that helps. MichaelWRHS965KE8PLM Quote
jk06
Hi,
Thanks
2 answers to this question
