Logan5 Posted October 3, 2014 Report Posted October 3, 2014 for some time I have wanted to utilize the VHF portion of my GMRS repeater antenna. I know you need notches and filters to do this. Will this sinclair power divider help me accomplish this task? I understand I would have to tune it to my frequency's. If not what does this product do? Thanks in advance Jim... Quote
zap Posted October 8, 2014 Report Posted October 8, 2014 A simple diplexer will do what you want. http://www.theantennafarm.com/catalog/ncg-comet-cf-4160n-7620.html I'd recommend the models with N connectors. Quote
Logan5 Posted October 8, 2014 Author Report Posted October 8, 2014 Thanks Zap, yes I only use "N" connectors. I will check out the link. Quote
Logan5 Posted October 8, 2014 Author Report Posted October 8, 2014 ah, not sure this would work, but I could be incorrect. I have much money invested in my equipment and I can see a product like this damaging something very expensive. I was told before that I would need notch and filter cans, and it sounds like the ability to tune the cans would also be very helpful. The sinclar sounds like notch and filters combined in a nice rack mountable module. I am e-mailing the seller now. Quote
zap Posted October 10, 2014 Report Posted October 10, 2014 They are very common in the amateur world, just not as common in commercial. Here's a little more reading on the subject. I probably should've lead with this but it didn't come to my mind until second post. http://www.repeater-builder.com/antenna/ant-sys-duplexers.html Quote
Guest spd641 Posted October 14, 2014 Report Posted October 14, 2014 ah, not sure this would work, but I could be incorrect. I have much money invested in my equipment and I can see a product like this damaging something very expensive. I was told before that I would need notch and filter cans, and it sounds like the ability to tune the cans would also be very helpful. The sinclar sounds like notch and filters combined in a nice rack mountable module. I am e-mailing the seller now.Logan,I am using a duplexer as zap described for several years on 2 different radios with no problems at all.I am thinking you are talking about the repeater on one side and a radio on the other.I would use a UHF single band on the repeater if that is what you are saying and use the dual band on 2 radios.You may find it better to use a dedicated UHF on the repeater for the frequency band and not a dual band amateur antenna...William Logan5 1 Quote
