WROA675 Posted December 6, 2021 Author Report Posted December 6, 2021 32 minutes ago, generalpain said: Can you add a mast to the one that is attached to the chimney to get it above the chimney? Thank you for your input @generalpain. Unfortunately I don't have enough cable to raise it above the chimney. However by moving it to the same A-frame (actually attached to my unit), as the Larsen, it will get me more slack. I'll be looking into a mast and ground plane setup for the 7900D today for it, making sure the two antennas are at least six feet apart and offset in height. How does that sound? Quote
