KCØVGJ Posted November 5, 2014 Report Share Posted November 5, 2014 Microwave linking still able to work or did the fcc killed that one too? Quote Link to comment Share on other sites More sharing options...
zap Posted November 5, 2014 Report Share Posted November 5, 2014 That's actually a good question. Although, the only microwave links I can think of that are budget friendly are 2.4 or 5.8 WLAN links (maybe 900 MHz). Quote Link to comment Share on other sites More sharing options...
quarterwave Posted November 5, 2014 Report Share Posted November 5, 2014 I'm not sure it was ever specifically mentioned in the GMRS rules, either allowed or not allowed. 6GHz microwave is used for all kinds of stuff. I don't see why a person could not use it to link a couple of stations, but I think it centers on channels, and the finite number of them. Is it necessary, and does it limit others ability to share the channels (if you have a 650 tied to a 700 in two adjacent locations, maybe 10 miles apart or even the same channel and further apart used just for creating more "coverage" for a unified system). Probably just comes back to common sense. Lots of dreamy projects out there, but practical and necessary is another story. 6 GHz microwave hop and the license will cost a few bucks. Quote Link to comment Share on other sites More sharing options...
zap Posted November 5, 2014 Report Share Posted November 5, 2014 To link multiple systems, you need a full duplex link repeater. You could do a point-to-point from one repeater to another on a simplex system but to add more than that you'd need a full duplex system. Their are two ways to easily perform multi-system links. Build a LAN network with 802.11 protocols using something similar to these…http://routerboard.com/RBMetal9HPn http://routerboard.com/RBMetal2SHPn http://routerboard.com/RBMetal5SHPn Or you could add an extra "link" radio to you're repeater that has the input/output of another repeater (this is easy to duplicate to link multiple repeaters together requiring a regular repeater for a hub and a link radio with the next closest repeater pairs on all the other repeaters you wish to link in). That is the only way I know to do a multiple link system wirelessly (there's always the running wire method). Quote Link to comment Share on other sites More sharing options...
KCØVGJ Posted November 6, 2014 Author Report Share Posted November 6, 2014 just asking back in 1990's pop linked his together so that he can shutdown both site incase he had too. Quote Link to comment Share on other sites More sharing options...
rpurchases10 Posted April 11, 2015 Report Share Posted April 11, 2015 Anyone have a good way to link 2 Quantars together for GMRS use? I don't really know if they are true "line of site", but with a spotting scope at location #1, (Building Mounted on roof of commercial building on a mountaintop) I CAN see Repeater Location #2 (500+' tower w/ our gear at 420') -- approximately 26 miles as the crow flies... I've done a few Cisco Aironet point-to-point 2.4ghz installations in the past (5-6 yrs ago) that spanned 6 miles or so at 2mbps.(only needed 512kbps anyway) But have no further experience w/ wireless anything... I do have wireline controllers w/ v.24 daughtercards installed in the Quantars. Was initially thinking of ROIP using UDS or similar 4-wire type modems,(the wireline cards were intended for use w/ microwave link / 4-wire leased line / etc.. and the Batboard gurus have been working on a linking project for some time now)but don't think I can get internet access at location #2. (I can get FIOS at #1 and can also get a frac or full T1 via copper) (supposedly the Quantars only need 64kbps of bandwidth -- though have heard the 128k figure floated about) Quote Link to comment Share on other sites More sharing options...
zap Posted April 12, 2015 Report Share Posted April 12, 2015 I was actually talking with a /\/\ tech earlier today about linking Quantars. Me and some friends have been wanting to get a VHF pair in Lubbock county and a VHF pair in either Williamson, Travis or Hays county (roughly 370 miles apart) just to run P25 with encryption. Anyway, what was learned from today, the Quantar really pre-dates ROIP so it was mainly shipped with an option for 4-wire leased line connection. That being said, there is currently Raytheon's NXU which takes 4-wire to VIOP (at $900 a pop) and a handful of others for around the $500-1000 range (not sure I would trust the $150-$200 Chinese options to be maintenance/headache free). That's about all I've found out specifically about Quantars… If you can see it, it's LOS. Oddly enough, I'm in the WISP business. Most of the stuff I deal with is Ubiquiti 5 GHz and 3.5 GHz APs. Usually run about 4-8 miles at the most but that being said an acquaintance just tested a hop using high gain dishes that runs from Denton, TX to Saginaw, TX (it's about 35 miles) and it's seeing 120 MB/s up and down. I'd run the path loss on it. So for a 2.4 GHz 26 mile hop, your looking at about 72 dB of loss…which should mean full speed as long as there isn't too much noise. Quote Link to comment Share on other sites More sharing options...
