headlayoutman1 Posted November 8, 2021 Report Share Posted November 8, 2021 I want to turn down the power on my GR1225 to 15 watts , it currently is putting 41 out of the duplexer . Can I do this with the programming software or is this a manual adjustment inside the transmit radio ? Quote Link to comment Share on other sites More sharing options...
0 gortex2 Posted November 8, 2021 Report Share Posted November 8, 2021 In the RSS under mode you should be able to select High or Low Power - Select low power and if its the 45 watt radio that should drop it to 25 if I remember correctly. Been a while since I used my R1225. Quote Link to comment Share on other sites More sharing options...
0 Radioguy7268 Posted November 9, 2021 Report Share Posted November 9, 2021 There were 2 versions of the R1225 made. The "High Power" version did 25 (low) or 40+ watts (high). Don't run an R1225 on high if you want it to live. They're famous for burning up. The high power versions are pretty easy to distinguish because they've got a pretty large set of cooling fins as compared to a typical MaxTrac or GM300 mobile. Model number M44GRC90C2AA. The lower power versions would run from 1-10 watts. They had a smaller set of cooling fins - similar to a typical Radius mobile. Model # M04GRC90J2AA If you have the 1225 CPS Software, and the proper equipment, you can tweak the radio's output power for the high/low settings, but I wouldn't recommend going below 23 watts or so on the High power version. Trying to put it down to 15 watts is asking for trouble. Repeater-builder is a great resource for Motorola repeaters. http://www.repeater-builder.com/motorola/gr1225/gr1225-overview.html gortex2 1 Quote Link to comment Share on other sites More sharing options...
headlayoutman1
2 answers to this question
