roadrunnernm Posted January 17, 2015 Posted January 17, 2015 Hello All, General Antenna Question. Vertical mounted antennas, such as on a vehicle. I know there's a up side to a bigger antenna, Is there a down side (other than the awkward physical size) of using a full wave length antenna versus using a quarter wave length antenna. Thanks in advance for your help and patience. Quote
JohnE Posted January 17, 2015 Posted January 17, 2015 IME no. other that theft.been running these for over 25 yrshttp://www.antenna.com/apg_products.cgi?id_num=10942 Quote
gdavis316 Posted January 17, 2015 Posted January 17, 2015 I have found a roof mounted 1/4 wave works just a good as anything i have used.....bigger is not always better. just my preference, and then no worries. Quote
zap Posted January 17, 2015 Posted January 17, 2015 Technically a full wave isn't naturally resonant (needs a matching coil). I've found very little difference between 1/4, 5/8 wave, and 5/8 over 5/8. Very little difference between 25 and 45 Watts too. I run a PCTEL wideband knob (it's almost a 1/4 wave long) as I use my radio on 3 different services. Quote
zap Posted January 17, 2015 Posted January 17, 2015 A general question deserves a good general answer..... In a nut shell, the antenna is only 1/2 of the system; the other half is the ground plane. In the case of your vehicle, it acts as the ground plane. Placement of your antenna on your vehicle will also affect your transmit and receive. If you mount the antenna on the rear of the vehicle, you will have a directional (or beam) system. Your transmit and receive will work better in the direction of the most metal, or in your vehicle's case, towards the front if mounted on the rear. For the best all around performance, mount the antenna in the middle of the vehicle and make sure it has a good contact with the metal of your vehicle. Fiberglass bodies, vinyl tops, etc., will greatly reduce your antenna's performance not to mention possibly damage your transmitter. If you have a fiberglass body, you will need to drill through it to the frame or roll cage and attach it to there. As for wavelengths, they say the best is a 5/8 wave, or a .64 wave if you can find or make one. 5/8 = .625. A full wave antenna tends to radiate most of it's signal up in the sky. At 5/8 you have the "flatest" take off angle of your signal, which in theory helps it cover the distance the best. As for power, for every doubling of power you will gain 3dbs. Each number on your radio's S-Meter (if it has one) is 6dbs. So if you are giving someone 3 S-units on his radio's meter at 25W of transmit power, you will need to increase your transmit power to 100W to give him 4 S-units on his meter, given you don't change anything else. With all that said, my best advice is for you to buy an antenna that is designed for the frequency band(s) you wish to talk on (450-470) for GMRS, and mount it as close to the center of your vehicle as you can, making sure it has good contact with the sheet metal of your vehicle's body. A good ground and matched SWR on your antenna system will do more for you than anything else. Not entirely accurate. You don't have attach an antenna on a fiberglass body to the metal chassis, especially with above 136 MHz communications. There are options such as no ground plane antennas (half-wave, matched antenna) which offer Unity gain without a ground plane as well as ground plane kits for running ground plane dependent antenna. Antenna placement on the roof of a vehicle isn't as important as most people think, as long as there is a quarter wave of ground plane (sheet metal) in all directions and you can get it as high as practically possible, you're golden. Quote
PastorGary Posted January 18, 2015 Posted January 18, 2015 I am using a 1/2 wave EM Wave # EMFLX-M10003-GPI antenna on one of our Chaplain Responder vehicles and we can't tell the performance difference between that one from EM Wave and a 5/8 PCTel Mosaic 5 db gain style. No ground plane required. Quote
gdavis316 Posted January 18, 2015 Posted January 18, 2015 pastor Gary, Great looking antenna, thanks for the info. Glenn Quote
zap Posted January 18, 2015 Posted January 18, 2015 That's a nice looking antenna pastor. I have a friend who may want a handful of those for his tractors since some of them don't have the OEM business band option. Quote
PastorGary Posted January 18, 2015 Posted January 18, 2015 I can recommend it for certain. There is a cutting chart with it and just make certain to use a quality NMO mount and cable. I have mine cut for 465 mhz - midway between the 467 T and 462 R frequencies and the SWR doesn't even register on the meter. My source was my local Kenwood dealer but they are also available from >>> http://shopwiscomm.com/EM-M10003-GPI-UHF-2dBi-Gain-Roof-Mount-Antenna-380-520-MHz-P2106563.aspx Quote
JohnE Posted January 18, 2015 Posted January 18, 2015 I am using a 1/2 wave EM Wave # EMFLX-M10003-GPI antenna on one of our Chaplain Responder vehicles and we can't tell the difference between that one from EM Wave and a 5/8 PCTel Mosaic 5 db gain style. No ground plane required and this one is mounted at the side of the rear spoiler on a Ford Edge. EM Wave Link >>> http://www.emwaveinc.com/PDF/02212013_New_Data_Install_Sheets/SS_VHF-UHF/Data_Sheets/EM-M10003-GPI_2dB.pdfI'll have to get one of those just to field test for S&G's.what I can tell you is that in horizon and weak signal areas for a unity there is a vast difference when using the taller 5db antennas in both TX & RX.at some point I will post pics of the antennas I have used over the yrs, but as I've said before I keep coming back to the AS mosaic.also w/regard to the using on a non metallic surface you will need to make some kind of ground plane. 1/4 wave at minimum but "if" you have the room to make it as big as the antenna is long that would be better. Quote
PastorGary Posted January 18, 2015 Posted January 18, 2015 Thanks, John - I have seen the Mosaic antennas used on fiberglass roofs by mounting a 12 inch circle of thin aluminum sheet stock under the NMO mount in the inside of the vehicle... works great. Just be aware that some fiberglass roofs are thinner than others, so FLEX may be present with the 31 inch center loaded Mosaics in some applications. Quote
quarterwave Posted January 19, 2015 Posted January 19, 2015 When I started in radio an older tech said the only difference in a 1/4 wave and gain antennae was the price. I have never gone wrong with a good old 1/4 wave on any of my UHF equipment. I used a 1/4 wave Vhf as a scanner antenna for years. The only time I had any better service out of a gain antenna was when I had a BC780 scanner in my work van. It had a ladder rack on it, and a UHF Motorola Spectrum (about 20 year old vintage) out shined the 1/4 VHF for both VHF and UHF reception, and 800 was about the same. Quote
Guest spd641 Posted January 19, 2015 Posted January 19, 2015 Well since we're showing off our antennas of choice, here's mine: http://www.hamradio.com/detail.cfm?pid=H0-001424I am curious about the performance of that antenna would you please enlighten us with your experience using this antenna...William Quote
zap Posted January 19, 2015 Posted January 19, 2015 The I am curious about the performance of that antenna would you please enlighten us with your experience using this antenna...William I have one on my Jeep and had one on my Trailblazer. They work as advertised as far as bandwidth goes but that's really the only good thing I have to say about them. I've never noticed one outperforming a 1/4 wave antenna and they aren't built to what I would call commercial standards. In fact for a while I actually switched to a Austin 500C (highly recommend that antenna but UHF is only about 10 MHz wide...after consulting with Richard he didn't think he could build one with enough UHF bandwidth to cover both 70 cm and GMRS) an noticed no change, especially on the VHF bandwidth. I don't see much of a point in DX'ing UHF FM. 10 miles simplex is more than adequate for me, especially for any simplex family road trip GMRS activities one might be doing. The only difference I've noticed between a common 5/8 over 5/8 and my little PCTEL knob is about 1/2 mile less repeater usage over flat terrain. I just run a regular Larsen NMOQ for VHF on my DD. For UHF I run this.http://www.hol4g.com/ac/product.aspx?number=MAX-BMLPV430&p=164550&sc=3566 My XJ currently has a CA2X4SR...it's okay. Working on moving over to the PCTEL and a NMO150WB where the Comet is. I may move the APRS tracker over to the 150 and then just run the Sti-Co quarter wave being used for ARPS for my VX-4000. Most current pics I have of the Jeep (has a Larsen NMO-Q with spring instead of the Sti-Co).http://i1245.photobucket.com/albums/gg586/zap_uh_lack/536357ED-81D3-4249-BA0A-D791BABD1506_zpszce0jkwz.jpg http://i1245.photobucket.com/albums/gg586/zap_uh_lack/3eb1317a-26f5-4207-befd-ae5ed1640f7f_zps0c093522.jpg Quote
zap Posted January 20, 2015 Posted January 20, 2015 I actually have two (if you want to really get into the reasoning of why that particular antenna is installed where it is)…the other was on my Trailblazer, on the roof. One night I was coming down a dimly lit city street and hit the antenna a little more than half way up on a low hanging tree branch traveling roughly 15 MPH, which is frankly slow to me. By then, the damage was done. The antenna had actually pulled the NMO mount out of the roof of the vehicle. Notice now, Comet sells a spring for that antenna. I guarantee you I'm not the first one who has pointed out to them (out of first hand experience) that the antenna they market as a Search and Rescue antenna, is way too stiff to be useful in a real Search and Rescue environment. They may have also been looking like they were facing several lawsuits. Back to the antenna being on my Trailblazer. While it was on the roof, I actually took the time to hook the antenna up to an analyzer and the results I got, are what I quoted in my previous post. Now back to where that antenna happens to be on my Jeep. I'm not sure if you've ever spent a lot of time in heavily wooded areas, especially driving vehicles through them, but you're always gonna hit antennas on something. After witnessing what happened to the roof of my daily driver, I carefully picked a mounting location that would both be sturdy enough for that antenna (until I found a different antenna solution that would suit my bandwidth needs). So I chose to sacrifice some signal to mount the antenna on something much more sturdy than the roof. I might also add, the only current use for that VHF 1/4 wave antenna on the roof of that Jeep, is for an APRS tracker I have in that Jeep. Here is another interesting little tit bit to look at. A quarter wave antenna (VHF or UHF) cost roughly $5-12 (or I can even get a Larsen NMO150WB for $30). My wideband UHF knobs, $30. The last CA2x4SR I bought cost roughly $75. However, if roof mounted, the CA2x4SR can cost you several hundred dollars at a body shop if one was to hit the antenna on something in the right spot. For the other options, you'd be worrying about dragging the roof before you ever even considered the antennas doing damage to the roof from snagging on something. That is the primary difference between commercial antennas and amateur antennas. Commercial antennas are designed to take a beating through a parking garage, in the woods, over rough terrain, even survive a roll over. You break a base, you can usually buy a base without buying a new antenna. You snap a whip, you can generally get another for less than $10. You just don't get that kind of quality out of an amateur antenna, and you definitely don't get that out of the 2x4SR. Quote
roadrunnernm Posted January 20, 2015 Author Posted January 20, 2015 Zap, Would you please post the make and model of your " My wideband UHF knobs". I'd like to see a picture of it. Thanks in advance. Quote
zap Posted January 20, 2015 Posted January 20, 2015 MLPV430 About a few inches smaller than a 1/4 wave 450-470MHz antenna. http://tapatalk.imageshack.com/v2/15/01/20/88f265ff22f14183171c7ff060ecf318.jpg Sent from my iPhone using Tapatalkhttp://tapatalk.imageshack.com/v2/15/01/20/377bf22c55c00fc06f5cd17c3133d971.jpg Quote
zap Posted January 21, 2015 Posted January 21, 2015 You don't. You either sacrifice the widebanded-ness for something like a Larsen nmo2/70 or go to something like a Larsen NMO150WB (wideband vhf 5/8 wave) and a wideband uhf antenna. I live in an extremely flat area. Storm chasing, never needed an antenna with gain. Our skyward guys have a decent uhf link system. Covers something like 10 counties. Sent from my iPhone using Tapatalk Quote
PastorGary Posted January 22, 2015 Posted January 22, 2015 Just a reminder - The Tri-Band Larsen NMO150/450/800 is a very competent antenna for dual or tri-band radios. We have one of these on a Chaplain Responder vehicle in Alabama and it works as well or better than individual 1/4 wave antennas in each band. Link >>> http://www.theantennafarm.com/catalog/larsen-nmo150-450-800-1050.html And, of course, it is excellent to be used with a digital scanner in a mobile application. Quote
zap Posted January 24, 2015 Posted January 24, 2015 What antenna did you get for your repeater? I'm still working through a pile of surplused dB antennas so I haven't had to purchase one yet. Sent from my iPhone using Tapatalk Quote
deputycrawford Posted January 27, 2015 Posted January 27, 2015 I have been told by a radio specialist that the 1/4 wave antenna has the flatest radiation take off angle. The 5/8 wave might give you that extra mile or so at the edge but the take off angle is higher. I have run them both on NMO mounts. I have not seen a difference so the 1/4 wave stays on. A little 6in or so 1/4 wave on a magnate mount NMO with 6 in or so of ground plan will do you well. The center of the roof is best in my opinion. I have a clip on NMO on the trunk of my convertible and drilled a hole in the roof of my truck. What can I say, I'm a diehard. I've drilled holes in many of my cars. Jerry Quote
