gman1971 Posted February 9, 2022 Report Posted February 9, 2022 As tittle reads. I don't have a fancy AeroFlex to do some of the MotoTRBO alignment stuff, so was wondering if anyone here could. Thanks in advance. G. Quote
Lscott Posted February 9, 2022 Report Posted February 9, 2022 5 hours ago, gman1971 said: As tittle reads. I don't have a fancy AeroFlex to do some of the MotoTRBO alignment stuff, so was wondering if anyone here could. Thanks in advance. G. Those radios need to "auto tune" feature of a Motorola test set? This is just for my info. The 6550's and 6580's I have need that so you can't manually set some of the RX parameters. Quote
gman1971 Posted February 9, 2022 Author Report Posted February 9, 2022 Correct, but I am also looking for tuning two of my EVX-5300 radios, they need a full alignment and I don't have the means to do that. G. Quote
PACNWComms Posted February 9, 2022 Report Posted February 9, 2022 I could do that if you want to ship to the west coast. That is if they are equivalent to XPR-4xxx/5xxx/e mobiles. I have TDMA Trbo Autotune. Might be a bit pricey on shipping though right now. My newest Vertex are a handful of VX-3200's analog only, back when Motorola first bought the company. My 3920 does seem to clean up some of the Sunny Comm XPR4550's people buy in this area. (I like the XPR4550 over the XPR5550e as people get into the menu and mess things up on the XPR5550e. Great radio, but too easy for end users to change settings and then get lost in the menu tree.) gman1971 1 Quote
gman1971 Posted February 9, 2022 Author Report Posted February 9, 2022 20 minutes ago, PACNWComms said: I could do that if you want to ship to the west coast. That is if they are equivalent to XPR-4xxx/5xxx/e mobiles. I have TDMA Trbo Autotune. Might be a bit pricey on shipping though right now. My newest Vertex are a handful of VX-3200's analog only, back when Motorola first bought the company. My 3920 does seem to clean up some of the Sunny Comm XPR4550's people buy in this area. (I like the XPR4550 over the XPR5550e as people get into the menu and mess things up on the XPR5550e. Great radio, but too easy for end users to change settings and then get lost in the menu tree.) Shipping shouldn't be too bad. The EVX-5300/5400 are not the equivalent of the XPR radios, they are DMR digital, but their own line designed in Japan... The alignment doesn't have anything specifically for digital AFAIK, but they are tuned/aligned using CE142 and not a separate tuner program. I think Vertex didn't have anything DMR when Moto purchased them, so Moto rebadged the 6550 as the VXD-720, the 4550 as the VXD-7200 and the XPR8400 as the EVX-R70. G. Quote
tweiss3 Posted February 9, 2022 Report Posted February 9, 2022 4 hours ago, PACNWComms said: I could do that if you want to ship to the west coast. That is if they are equivalent to XPR-4xxx/5xxx/e mobiles. I have TDMA Trbo Autotune. Might be a bit pricey on shipping though right now. My newest Vertex are a handful of VX-3200's analog only, back when Motorola first bought the company. My 3920 does seem to clean up some of the Sunny Comm XPR4550's people buy in this area. (I like the XPR4550 over the XPR5550e as people get into the menu and mess things up on the XPR5550e. Great radio, but too easy for end users to change settings and then get lost in the menu tree.) You do need the RF adapter assembly: It does look like the rest of the alignment/testing can be done with the standard programming cable though. Quote
gman1971 Posted February 9, 2022 Author Report Posted February 9, 2022 @tweiss3 I have a cable for doing that already, but its not the MotoTRBO radios that need an alignment. G. Quote
tweiss3 Posted February 9, 2022 Report Posted February 9, 2022 5 minutes ago, gman1971 said: @tweiss3 I have a cable for doing that already, but its not the MotoTRBO radios that need an alignment. G. Find out what radio shops service WISCOM and give them a call. I know MARCS-IP have all their dealers/shops listed, perhaps WI has the same thing? Quote
gman1971 Posted February 9, 2022 Author Report Posted February 9, 2022 A WISCOM shop is somewhere nearby... will probably give'em a call to see what services they offer. Thanks for the heads up! G. Quote
PACNWComms Posted February 10, 2022 Report Posted February 10, 2022 4 hours ago, tweiss3 said: You do need the RF adapter assembly: Yes, that is the one I use for XPR7xxx series Trbo handhelds. Good luck gman1971, I would only be able to do the manual/calibration, not Autotest, test on those Vertex mobiles. Quote
gman1971 Posted February 10, 2022 Author Report Posted February 10, 2022 2 hours ago, PACNWComms said: Yes, that is the one I use for XPR7xxx series Trbo handhelds. Good luck gman1971, I would only be able to do the manual/calibration, not Autotest, test on those Vertex mobiles. There are no auto-tests on the Vertex, its all manual. G. Quote
