Guest Jerry Posted February 18, 2022 Report Posted February 18, 2022 I hooked up one of my GMRS radios about 3 weeks after sitting on the shelf for 2 years. I found the Chicago repeater and was so impressed with the professional radio operators!! My question is this: what programming software is there available for programming a Motorola CM 300 mobile if any? All my channels are Simplex. Thank you for any advice Jerry Quote
gortex2 Posted February 18, 2022 Report Posted February 18, 2022 If its the early CM300 its Commercial Series PPS. It can still be purchased and downloaded from motorola. You will need a programming cable in addition. If its the new CM300d then same applies but uses Trbo Software. Quote
