Repeater use
WRPD571
4 answers to this question
If I set up a MXT500 as a repeater can I use it for general comm also ?
thanx,Don
Internally, repeaters consist of at least two radios. The MXT500 is only one. Depending upon how you built everything else in the system out, including whether you used one antenna or two, whether you were using a duplexer, and whether or not you built custom circuitry to allow you to integrate a mic while the two radios are interconnected, then perhaps.
The Wouxon KG-1000G is the only Part 95e radio I know of that is built to be used as a component of a custom limited-use repeater build, and OffRoaderX did it. It has the internal circuitry necessary for interconnecting two like models, and has modes for changing the radios behavior to operate as components of a repeater system. If using this model, yes you could use its mic to transmit while the radio is configured as a repeater, but only on the repeater Tx frequency. However, to use the radios for general comms you would need to be using separate antennas and you would need to switch the radios back into standard mode.
My advice, if you want a repeater, buy and put up a purpose built repeater.
Michael
WRHS965
KE8PLM
Link to comment
Share on other sites
How do you plan on setting up your MXT500 as a repeater?
Well while eating a bowel of crow… I have reread the user manual and have come to the conclusion “ ain’t happening “. I can set up 8 channels to talk to repeaters but that’s it. Thank you for the question. It led me to what I needed to know.
Don
Sent from my iPhone using Tapatalk
Link to comment
