Need help - first time setting this up
WRQU236
Greetings,
As I have finally gotten my repeater hardware set completed, I have begun to work on the linking side of things. As it turns out, things don't seem to be working. MyGMRS isn't seeing the node controller. Keying up on my produces a ~ keystroke on the CLI.
I have waited about 45 minutes so far from a bootup.
Executing both sudo asterisk -r and simpleusb-tune-menu returns with "Segmentation fault" and nothing else. I don't see any real getting started guide regarding how to get this thing set up either. All I have done so far is setting the CW ID to the repeater callsign in rpt.conf. The base image was also backed up prior to touching anything.
Setup:
* Raspberry Pi 3 model b+ (connected through Ethernet. UDP 4569 is forwarding to the Pi)
* URIxB interface
* Retevis RT97s repeater
* Ed Fong J-pole
Is there something I'm missing here?
0 answers to this question
There have been no answers to this question yet
