I was curious about a couple of mobile mag mount antennas. I recently purchased a Kenwood TK880 from ebay and it came with an antenna. I just figured it was a junk antenna, but it was this one https://www.mobilemark.com/product/a1845-series/
The actual antenna, that goes into the mount has a sticker 450-470 but testing SWR it is well over 3.5:1. I've had luck in the past using brazing rods, so I tried it and SWR dropped way down, to about 1.7:1. Testing with a continuity tester, there is continuity between the center pin of the PL-259 and the outer screw on part. If I take off the antenna, there is no continuity, so I assume the base is good. When I check the actual antenna though (photo attached) there is continuity between the center pin and the screw on part. Is that normal? I know my Midland MXTA26 isn't like that
Flameout
7 answers to this question
