Dummy load.
WRQZ484
3 answers to this question
Just because I own one from ages past... https://mfjenterprises.com/collections/dummy-load/products/mfj-260c
The derating curve gives it 2.5-3 minutes at 50W before you have to allow it to cool down (2 minutes). At <25W there is no time limit. Full 300W is only 30 seconds.
You will need a short low-loss coax with suitable connectors (and/or adapters) to match radio and load connectors. Note: MFJ has a version with N connector in place of PL-259 (SO-239 -- for some reason the cable plug and the equipment socket have different numbers). The N version may show a slightly better SWR at the high VHF and UHF range (makes one wonder what industry rep called the 259/239 connectors "UHF").
